Visitor samuelnj
Compiling AC1200 driver for ZCU102 board
I'm attempting to have USB wifi support on my SCU102 board. I'm new to this and when I try to compile the driver found at https://github.com/abperiasamy/rtl8812AU_8821AU_linux, I get the following error:
make ARCH=x86_64 CROSS_COMPILE=aarch64-linux-gnu- -C /lib/modules/4.10.0-32-generic/build M=/home/user/Documents/driver/rtl8812AU_8821AU_linux modules
make[1]: Entering directory '/usr/src/linux-headers-4.10.0-32-generic'
arch/x86/Makefile:140: CONFIG_X86_X32 enabled but no binutils support
CC [M] /home/user/Documents/driver/rtl8812AU_8821AU_linux/core/rtw_cmd.o
aarch64-linux-gnu-gcc: error: unrecognized argument in option ‘-mcmodel=kernel’
aarch64-linux-gnu-gcc: note: valid arguments to ‘-mcmodel=’ are: large small tiny
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-mno-sse’; did you mean ‘-fno-dse’?
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-mno-mmx’
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-mno-sse2’; did you mean ‘-fno-dse’?
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-mno-3dnow’
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-m64’
aarch64-linux-gnu-gcc: error: unrecognized command line option ‘-mno-red-zone’; did you mean ‘-fno-regmove’?
scripts/Makefile.build:294: recipe for target '/home/sam/Documents/driver/rtl8812AU_8821AU_linux/core/rtw_cmd.o' failed
make[2]: *** [/home/user/Documents/driver/rtl8812AU_8821AU_linux/core/rtw_cmd.o] Error 1
Makefile:1524: recipe for target '_module_/home/sam/Documents/driver/rtl8812AU_8821AU_linux' failed
make[1]: *** [_module_/home/user/Documents/driver/rtl8812AU_8821AU_linux] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.10.0-32-generic'
Makefile:1584: recipe for target 'modules' failed
make: *** [modules] Error 2
Not exactly sure what I'm doing wrong here or if I'm even taking the right approach. Any advice would be appreciated.
Visitor eatnafou
Re: Compiling AC1200 driver for ZCU102 board
I get an almost identical error. Did you ever solve it? If so, please let us know. Thanks.
Visitor samuelnj
I did get it resolved with some modifications to the makefiles, etc.
I assume you're using petalinux tools for the linux image as well?
NOTE:
$CROSS_COMPILE=aarch64-linux-gnu-
$ARCH=arm64
My solution is below:
First, clone the git repository to obtain the files:
$ git clone https://github.com/abperiasamy/rtl8812AU_8821AU_linux
Now, we are going to edit some of the files to successfully cross-compile.
$ cd rtl8812AU_8821AU_linux
$ gedit core/rtw-br-ext.c
On line 25 of this file insert:
#include <net/ip6_checksum.h>
Close and save the file, then open and edit the makefile:
$ gedit Makefile
Replace line 1584 with:
$(MAKE) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) -C <petalinux-project-directory>/build/tmp/work/plnx_aarch64-xilinx-linux/linux-xlnx/4.9-xilinx-v2017.2+gitAUTOINC+5d029fdc25-r0/linux-plnx_aarch64-standard-build M=$(shell pwd)  modules
Now, compile the driver and move it to the appropriate folder for drivers on the board:
$ make
$ cd ..
$ scp -r rtl8812AU_8821AU_linux root@<IPADDRESS>:/lib/modules/4.9.0-xilinx-v2017.2/kernel/drivers/net
If the driver doesn’t compile, try commenting out line 6 (EXTRA_CFLAGS += -Werror). And set the environmental variables CFLAGS and LDFLAGS to “”. If it says the directory is missing for the kernel, run petalinux-build on your project.
