Compiling source code in linux mode
Hi all,
I have a problem in compiling my source code in EDK,
when I select linux as OS and set variables, I can just run libgen, and when I run bulid application, it occures one error which explains
no boot.o file in $EDK\gnu\powerpc-eabi\nt\powerpc-eabi\lib.
I test it in EDK 7.1 and 10.1, but result is same.
how can I  compile my source code in mvl3.1 OS mode?
Re: Compiling source code in linux mode
Can you look at http://www.xilinx.com/support/answers/17462.htm
For more info look at http://forums.xilinx.com/xlnx/board/message?board.id=EMBEDDED&thread.id=114
Hem.
Hi hem,
thanks for your help,
but in " http://forums.xilinx.com/xlnx/board/message?board.id=EMBEDDED&thread.id=114"
I could not understand meaning of "You will build the kernel in the 3rd parties Platform.  "
I must create or use a crosstool?
correct you must use the MontaVista SW suite to build a kernel.
When Linux is selected as the OS, EDK is only used to build the BSP, it is not used to compile source code.
