Visitor yywilson
Configure env parameters of U-boot from petalinux
I am using petalinux 2017.2. Under u-boot command line and enter command "printenv", the list of environment parameters are shown. I know how to modify and save them with "setenv" and "saveenv". But is there a way to modify a file contains the parameters in petalinux? Then I do not have to modify the parameters every time download to a new device.
Re: Configure env parameters of U-boot from petalinux
Please check the below answer record, which gives an example of adding/modifying uboot environment variables
https://www.xilinx.com/support/answers/69780.html
Best Regards
Shabbir
Best Regards
Shabbir
