Visitor yywilson
Configure uboot in Petalinux 2017.2
Two questions:
1. How to modify configuration of uboot in Petalinux 2017.2? Is there any other modification should be made to use custom uboot configuration such as disable "uboot autoconfig" in "petalinux-config"?
2. Although "petalinux-config -c u-boot" is not introduced in user guide, it will show menuconfig. Is it safe to modify something within the menu?
Re: Configure uboot in Petalinux 2017.2
Hi Wilson,
you could modify u-boot configuration using petalinux-config -c u-boot. Modifications  will be updated the u-boot configuration in petalinux.
Best Regards
Kranthi
Hi Wilson,
Best Regards
Kranthi
@gudishak
Thanks for your information. Could you tell me where is the u-boot configuration file? Sometimes I need to modify it manually.
