Correspondence between Concat and IRQ_F2P?
Correspondence between Concat and IRQ_F2P,As shown in the following figure:
Re: Correspondence between Concat and IRQ_F2P?
Hi @xilinx-zhaosheng,
Could you explain what you want to know?
The concat IP only create a bus from single pins (this is just a way to connect).
Then just a rising edge on an interrupt input trigger the corresponding interrupt routing in the PS.
Florent
Florent
