Could not find elf file in qt application
I have downloaded ZYNQ+BASE+TRD 14.5 and as per the instruction the .elf of sobel_cmd and sobel_qt should be renamed with sobel_cmd and sobel_qt so that the executables can run by shell skript inside SD card.
But, I am not getting .elf file for sobel_qt....I have only mainwindow.o , main.o ...files
