motagiyash
Coustom U-boot Petalinux issues
Hellow experts,
I am using red pitaya board with zynq 7010 in it.
I have been working with petalinux for a wile and i am not able to figure out the problem.
after some follow ups i am using the uboot and linux kernel given by the red pitaya board.
avaliable on :
https://github.com/RedPitaya/linux-xlnx
https://github.com/RedPitaya/u-boot-xlnx
I also change the uboot target to the zynq_redpitaya_defconfig in petalinux-config window.
i have configuration issues i guess.
WARNING: /opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.3.bb: Exception during build_dependencies for PKG_kernel-image
WARNING: /opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.3.bb: Error during finalise of /opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.3.bb
ERROR: ExpansionError during parsing /opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.3.bb
motagiyash
i solved it was able to boot petalinux linux on red pitaya.
thanks
-yash
motagiyash
thanks
-yash
