Observer ngrubaugh
Create BOOT.mcs in SDK
So I have built all the files required for BOOT.mcs in Petalinux and have migrated them to a windows machine that has SDK on it to run the bootgen command. I can see the Xilinx Tools -> Create Zynq Boot Image but I don't see an equivalent option in the tools menu for a Microblaze.
Will I need to use the XMD console? I know that bootgen is a command I can run but the -help function doesn't give me much insight into how to set up the command with a path to the Petalinux directory with all the files in it.
Scholar sampatd
Re: Create BOOT.mcs in SDK
Check page 85 of the following guide for bootgen commands:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug1043-embedded-system-tools.pdf
 You can also use tcl command write_cfgmem. For more info refer to ug835
 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug835-vivado-tcl-commands.pdf
