ray110
Create read-only partitions from config files
Hi everyone,
I'm looking to create read-only partitions on the QSPI Flash where boot files are stored.
There is a possibility to pass a command line from U-Boot to the kernel at bootup if CONFIG_MTD_CMDLINE_PARTS is enabled, which would look something like this:
mtdparts=spi0.0:8m(U-Boot)ro,128k(Bootenv),16m(Kernel)ro,32m(RootFS)ro,-(Data)
So I'm trying to make this static in the kernel without passing it from U-Boot.
There is the following code in components/plnx-workspace/device-tree/device-tree-generation:
&qspi {
 #address-cells = <1>;
 #size-cells = <0>;
 flash0: flash@0 {
  compatible = "n25q512a","micron,m25p80";
  reg = <0x0>;
  #size-cells = <1>;
  spi-max-frequency = <50000000>;
  partition@0x00000000 {
   label = "boot";
   reg = <0x00000000 0x00500000>;
  partition@0x00500000 {
   label = "bootenv";
   reg = <0x00500000 0x00020000>;
  partition@0x00520000 {
   label = "kernel";
   reg = <0x00520000 0x00a80000>;
  partition@0x00fa0000 {
   label = "spare";
   reg = <0x00fa0000 0x00000000>;
 As this is generated code, the question is: where do I customize this from to make the partitions read-only, and what would be the option to pass?
Thanks for your time
mb1000
There is an option in Flash Settings menu to add 'flash partition flags'.  The only supported one is read-only.  The problem is that I have been unable to get this mechanism to work.
An alternative is to add something to system-user.dtsi to manually add the 'read-only;' option to the partition entry in the device tree.
I used something like the following, but obviously tailored to your specific flash configuration.  I tested a build using this mechanism and the partitions are definitely read-only; flash_erase and flashcp fail with permission error.
&amba {
               spi@e000d000 {
                              flash@0 {
        read-only;
