Cross compile tcpdump for petalinux
Hi, all. I'm trying to get tcpdump for petalinux but I've found anything about how to cross-compile it for Microblaze. Anyone already made tcpdump work on petalinux on MicroBlaze?
Hi @jamellyf
Try adding the below line to project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend in your petalinux microblaze project and enable the same in rootfs user packages and rebuild
IMAGE_INSTALL_append = " tcpdump"
Hi @jamellyf
