Cross-compiling GPSD for Petalinux
I'm currently new to the linux development.I've built a custom BSP for my zynqMP board. Now I want to add GPSD (http://www.catb.org/gpsd/) to the rootfs.
I'm following the petalinux-build flow. Apart from downloading the tarball and extracting it under apps-recipes how should I proceed?
Regards.
Re: Cross-compiling GPSD for Petalinux
There is a yocto recipe here:
https://layers.openembedded.org/layerindex/recipe/1120/
Open the project-spec\meta-user\recipes-core\images\petalinux-image.bbappend
IMAGE_INSTALL_append = " gpsd"
petalinux-config -c rootfs
user packages -> [*] gpsd
petalinux-build
petalinux-build
Thank you.
I also want to learn how to do this without the yocto recipe. I will be adding other libraries and apps to the rootfs.
There are very few examples out there for cross compiling.
Thank you.
You can also build your own modules and apps in Petalinux. See ug1144 for help here
