Cross compiling logrotate for armv7/arm-linux-gnueabihf
How to cross compile logrotate utility for armv7/arm-linux-gnueabihf after downloading repo from https://github.com/logrotate/logrotate.git and enable it in petalinux.
Re: Cross compiling logrotate for armv7/arm-linux-gnueabihf
HI srikanth.a.v@atonarp.com
Please follow below steps to include this utility as apart of your rootfs:
vim project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
add below line
IMAGE_INSTALL_append = " logrotate"
petalinux-config -c rootfs
user packages --> [*] logrotate
petalinux-build
For your info, you can find the recipe at this location:
/petalinux-v2018.2-final/components/yocto/source/arm/layers/core/meta/recipes-extended/logrotate/logrotate_3.12.3.bb
You no need to seperatly crosscompile it, if you follow the above steps, petalinux  will crosscompile this add into the rootfs.
Thanks & regards
Aravind
add below line
petalinux-build
Thanks & regards
Aravind
Thanks its working.
Same way we can use this for cronie utility?
Hi srikanth.a.v@atonarp.com
Yes, you can follow same steps.
For your reference steps mentioned  below:
add below line
IMAGE_INSTALL_append = " cronie "
user packages --> [*] cronie
petalinux-build
Thanks & regards
Aravind
Thanks its worked.
