Visitor tahoe250
Custom HDL AXI Lite
Hello All,
I am looking for tutorial that guides through the entire flow. Meaning,  create a vivado project then create a linux image based on that hardware design.  I am trying to figure how to write an application that would access my custom HDL module through Linux.  I have already verified that my custom HDL module works through the AXI lite bus interface.  I created a bare metal application to test my custom HDL module and everything works as I expect it.  So, the next step would be doing the same through a Linux application.  Hope that makes sense.  Also,  I am currently working with vivado within Windows 10 would it make more sense to install vivado on a Linux Box?   I have gone through this tutorial:
https://github.com/Digilent/Petalinux-Zybo-Z7-20/blob/master/README.md?_ga=2.65706535.861548781.1558477480-254828324.1551742247
Basically, installed Petalinux on VM linux box.  Another thing, I had a really hard time installing Petalinux on Ubuntu 18.04.2.  I gave up and went to 16.04.4 then seems to work just fine. Not sure if I understand that one.   Any guidance would be tremendously appreciated.
P.S I am currently working with Zybo-Z7 20 board.
回复: Custom HDL AXI Lite
@tahoe250
I would suggest you refer to UG1165 and its design files as a tutorial.
And if you check Installation Requirements in UG1144, Petalinux doesn't support Ubuntu 18.04. You can find the reason in below AR.
https://www.xilinx.com/support/answers/71448.html
