aripod
Custom Hardware with UIO
Yet another similar post about UIO and petalinux. I have a custom ip which simply writes the 8 LEDS from the zedboard. And as outputs it reads the values from the switches and also generates a pulse with a push button. This is in a custom AXI-IP rather than using the AXI-GPIO. So, on the slv_reg0 I receive the value for the LEDS and on slv_reg1 I write the values from the switches on every rising edge of the axi_clk. The pulse generated from the PB is connected to IRQ_F2P[0:0]. This works fine in a standalone application coded in SDK with the auto generated functions to read and write the custom IP plus it reacts to the interrupt.
Just in case, I am using vivado and petalinux 2017.3.
Now I am eager to replicate the behavior on linux with the UIO. Therefore, this are the steps that I am following:
1. Create a new petalinux project
petalinux-create --type project --template zynq --name custom_ip
2. Get the custom hardware generated with vivado/sdk
petalinux-config --get-hw-description=/home/ariel/Documents/vivado_prjts/custom_ip/custom_ip.sdk
3. Configure the kernel with
CONFIG_UIO=y
CONFIG_UIO_PDRV_GENIRQ=y
4. Build the project so it autogenerates the files needed
petalinux-build
5. Edit  <plnx_proj_root>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi so it looks like this:
/include/ "system-conf.dtsi"
    user_io@43c00000{
    compatible = "custom_ip,generic-uio,ui_pdrv";
    status = "okay";
	interrupt-parent = <&intc>;
	interrupts = <0 29 4>;
	reg = <0x43c00000 0x10000>;
I extracted the values form interrupt-parent, interrupts and reg from  <plnx_proj_root>/components/plnx_workspace/device-tree/device-tree-generation/pl.dtsi. Also, the user_io@43c00000 is from pl.dtsi
6. Following some similar posts, they recommend edit <plnx_proj_root>/components/plnx_workspace/device-tree/device-tree-generation/system-conf.dtsi so it looks like this:
chosen {
bootargs = "console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio";
But I have seen that this is autogenerated. Therefore, after petalinux-build, the uio_pdrv_genirq.of_id=generic-uio part is removed. One suggestion was to edit <plnx_proj_root>/components/plnx_workspace/device-tree/device-tree-generation/system-top.dts but this is also autogenerated and therefore modified.
On this, I noticed that <plnx_proj_root>/project-spec/meta-user/recipes-dt does not exist.
$ ls <plnx_proj_root>/project-spec/meta-user/
conf  COPYING.MIT  README  recipes-apps  recipes-bsp  recipes-core  recipes-kernel
7. Build the project with my changes with petalinux-build
8. Package it:
petalinux-package --boot --format BIN --fsbl ./images/linux/zynq_fsbl.elf --fpga ./images/linux/design_1_wrapper.bit --u-boot --force
9. Copy <plnx_proj_root>/images/linux/* to the BOOT partition of the SD.
When linux boots, in /dev I do not see /dev/uio, but if I can read the switches and write the LEDS with:
devmem 0x41200000 32 0x000000ff   --To write to the LEDS
devmem 0x41210004                 --To read the switches.
The issue is as /dev/uio is missing, i will not be able to follow this guide to write a C application to include it later on petalinux.
The question is what step should I modify, add or remove to have /dev/uio 'created' so I can access it in a C code via the UIO?
Thank you for the help
akshayva
We have seen an issue with generic-uio in previous versions of petalinux where eventhough you select it as a [Y], it would still not come up in /dev/. Please try this workaround. One thing to remember here is all changes to recipes-dt will be overwritten except for the file system-user.dtsi. You need to use this file only to add changes to device-tree.
How to enable UIO drivers so that it comes up after Linux bootup.
Description
I have enabled the UIO drivers in the kernel config, but after Linux boots up I try
ls /dev/uio*
ls: /dev/uio*: No such file or directory
There are no devices listed under /dev
What should I do to make these come up after kernel boots.
Solution
  1. In the kernel config make the following changes to the kernel config menu for the User space I/O platform driver.
  1. In the device tree add the compatible string "generic-uio" for the gpio devices as well as add uio_pdrv_genirq.of_id=generic-uio to the kernel boot args.
 This should be added to system-user.dtsi inside
chosen {
        bootargs = "earlycon=cdns,mmio,0xFF000000,115200n8 uio_pdrv_genirq.of_id=generic-uio";
&axi_gpio_0 {
        compatible =  "generic-uio";
&axi_gpio_1  {
 Build Linux and boot it up. Once you boot it up you should see the uio nodes after you ls into the /dev directory.
Please mark an answer "Accept as solution" if a post has the solution to your issue.
akshayva
Check your modules.dep under /lib/modules/. See if uio_pdrv_genirq exists as loadable module and load it using insmod <path-to-module>.
Check status of module using lsmod. See if nodes are created in /dev
aripod
Hello @akshayva,
I cannot see anything with uio in modules.dep:
root@custom_ip:~# cat /lib/modules/4.9.0-xilinx-v2017.3/modules.dep
kernel/crypto/echainiv.ko:
kernel/crypto/hmac.ko:
kernel/crypto/sha256_generic.ko:
kernel/crypto/drbg.ko:
kernel/crypto/jitterentropy_rng.ko:
kernel/drivers/usb/gadget/function/usb_f_ss_lb.ko: kernel/drivers/usb/gadget/libcomposite.ko
kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko: kernel/drivers/usb/gadget/libcomposite.ko
kernel/drivers/usb/gadget/legacy/g_zero.ko: kernel/drivers/usb/gadget/libcomposite.ko
kernel/drivers/usb/gadget/libcomposite.ko:
kernel/drivers/virtio/virtio.ko:
kernel/drivers/virtio/virtio_ring.ko:
kernel/drivers/remoteproc/remoteproc.ko: kernel/drivers/virtio/virtio.ko kernel/drivers/virtio/virtio_ring.ko
kernel/drivers/remoteproc/zynq_remoteproc.ko: kernel/drivers/remoteproc/remoteproc.ko kernel/drivers/virtio/virtio.ko kernel/drivers/virtio/virtio_ring.ko
kernel/drivers/rpmsg/rpmsg_core.ko:
kernel/drivers/rpmsg/virtio_rpmsg_bus.ko: kernel/drivers/rpmsg/rpmsg_core.ko kernel/drivers/virtio/virtio.ko kernel/drivers/virtio/virtio_ring.ko
kernel/net/802/p8022.ko: kernel/net/llc/llc.ko
kernel/net/802/psnap.ko: kernel/net/llc/llc.ko
kernel/net/802/stp.ko: kernel/net/llc/llc.ko
kernel/net/ipv4/ipip.ko:
kernel/net/8021q/8021q.ko:
kernel/net/llc/llc.ko:
kernel/net/bridge/bridge.ko: kernel/net/802/stp.ko kernel/net/llc/llc.ko
root@custom_ip:~# cat /lib/modules/4.9.0-xilinx-v2017.3/modules.dep | grep uio
root@custom_ip:~#
What about step6? Is it correct?
In step 3, should they be =y or =m? I had it with =y. I switched to =m and now this is what I got:
kernel/drivers/usb/serial/usbserial.ko:
kernel/drivers/usb/serial/ftdi_sio.ko: kernel/drivers/usb/serial/usbserial.ko
kernel/drivers/uio/uio.ko:
kernel/drivers/uio/uio_pdrv_genirq.ko: kernel/drivers/uio/uio.ko
kernel/drivers/uio/uio_dmem_genirq.ko: kernel/drivers/uio/uio.ko
kernel/drivers/uio/uio_xilinx_apm.ko: kernel/drivers/uio/uio.ko
I loaded it with insmod but I still cannot see /dev/uio but it shows with lsmod:
root@custom_ip:/lib/modules/4.9.0-xilinx-v2017.3/kernel/drivers/uio# lsmod
    Not tainted
uio_pdrv_genirq 2754 0 - Live 0xbf01c000
uio 7190 1 uio_pdrv_genirq, Live 0xbf000000
Thanks for the help!
EDIT1:
I saw in another post that I should also edit pl.dtsi and add to compatible generic-uio. Should I?
	amba_pl: amba_pl {
		#address-cells = <1>;
		#size-cells = <1>;
		compatible = "simple-bus";
		ranges ;
		custom_ip_0: custom_ip@43c00000 {
			compatible = "xlnx,custom-ip-1.0 generic-uio";
			xlnx,s00-axi-addr-width = <0x4>;
			xlnx,s00-axi-data-width = <0x20>;
akshayva
Description
ls /dev/uio*
Solution
chosen {
&axi_gpio_0 {
&axi_gpio_1  {
aripod
I just came to post this. I edited the system-user.dtsi (as stated in ug1144) adding the bootargs for uio plus the compatible for my custom_ip and that was it. It works now.
I have one more thing.....what if I want to user another kernel, for example ubuntu (as suggested here) so I can have apt-get for example and also have to possibility to store changes in the sd card on the second partition (rootfs)?
akshayva
I 'm not sure about whether that is possible. But here are some options:
1. Use the smart package manager instead that comes with Yocto and part of petalinux. To enable this, please add:
│ Location: │
│ -> Filesystem Packages │
│ -> devel │
│ -> python │
│ (1) -> python-smartpm
2. Follow steps on this wiki-xilinx page which talks about Ubuntu on ZYNQ but its fairly old.(http://www.wiki.xilinx.com/Ubuntu+on+Zynq)
aripod
Hello @akshayva,
Other thing...I have been following this guide on how to write the UIO C code but it is general. My question is, if I have a custom AXI-IP with 4 32 bit register. How do I write to register N and read from register M?
Thanks again for the help!
EDIT 1: Perhaps to make it more clear, this is what I do in a standalone code in SDK in the interrup handler:
	u32 leds;
	leds = CUSTOM_IP_mReadReg(CUSTOM_IP_BASEADDR, CUSTOM_IP_S00_AXI_SLV_REG1_OFFSET);	// Read from the IP.
	CUSTOM_IP_mWriteReg(CUSTOM_IP_BASEADDR + CUSTOM_IP_S00_AXI_SLV_REG0_OFFSET, 0, leds);	// Write to the IP.
akshayva
/dev/uioX is used to access the address space of the card. Just use mmap() to access registers or RAM locations of your card.
Please refer to this document for more information on how to use UIO. It is using mmap() on the /dev/uioX device file.
https://www.kernel.org/doc/html/v4.12/driver-api/uio-howto.html
akshayva
Using linux kernel driver will give you a standard interface to the Custom IP and you should be able to use the same attributes as any other UIO device for AXI Custom IP. All you need to do is map on the device file and access register.
aripod
Thank you @akshayva for the help. I managed to read and write to different register in my custom ip:
This is my (auto-generated) pl.dtsi:
	amba_pl: amba_pl {
		#size-cells = <1>;
		ranges ;
			compatible = "xlnx,custom-ip-1.0";
The system-user.dtsi:
	model = "Zynq Zed Development Board";
	compatible = "xlnx,zynq-zed", "xlnx,zynq-7000";
	usb_phy0: phy0@e0002000 {
		compatible = "ulpi-phy";
		#phy-cells = <0>;
		reg = <0xe0002000 0x1000>;
		view-port = <0x0170>;
		drv-vbus;
&clkc {
	ps-clk-frequency = <33333333>;
chosen {
amba_pl: amba_pl {
			interrupts = <0 29 1>;
&usb0 {
	dr_mode = "host";
	usb-phy = <&usb_phy0>;
And the C code:
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <poll.h>
#include <fcntl.h>
#include <errno.h>
#include <unistd.h>
#include <sys/mman.h>
#define CUSTOM_IP_MAP_SIZE                  0x10000
#define CUSTOM_IP_BASEADDR	                0x43C00000
#define CUSTOM_IP_S00_AXI_SLV_REG0_OFFSET   0
#define CUSTOM_IP_S00_AXI_SLV_REG1_OFFSET   4
#define CUSTOM_IP_S00_AXI_SLV_REG2_OFFSET   8
#define CUSTOM_IP_S00_AXI_SLV_REG3_OFFSET   12
int main(void)
    uint32_t leds=0x0;
    int fd = open("/dev/uio0", O_RDWR);
    void *ptr;
    if (fd < 0) {
        perror("open");
        exit(EXIT_FAILURE);
    ptr = mmap(NULL, CUSTOM_IP_MAP_SIZE, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
    while (1) {
        uint32_t info = 1; /* unmask */
        ssize_t nb = write(fd, &info, sizeof(info));
        if (nb < sizeof(info)) {
            perror("write");
            close(fd);
            exit(EXIT_FAILURE);
        struct pollfd fds = {
            .fd = fd,
            .events = POLLIN,
        int ret = poll(&fds, 1, -1);
        if (ret >= 1) {
            nb = read(fd, &info, sizeof(info));
            if (nb == sizeof(info)) {
                /* Do something in response to the interrupt. */
                printf("Interrupt #%u!\n", info);
                leds = *((unsigned *)(ptr + CUSTOM_IP_S00_AXI_SLV_REG1_OFFSET));    //Read from the IP (slv_reg1).
                printf("Switches: %d\n", leds);
                *((unsigned *)(ptr + CUSTOM_IP_S00_AXI_SLV_REG0_OFFSET)) = leds;    //Write to the IP (slv_reg0).
                printf("Wrote to leds\n");
        } else {
            perror("poll()");
            close(fd);
            exit(EXIT_FAILURE);
    close(fd);
    exit(EXIT_SUCCESS);
Hopefully it helps someone with the same doubts.
ronnywebers
Advisor
Advisor
@aripod, regarding the dtsi entry :
chosen {
fyi : you can set manual bootargs in the config menu (at least in my Petalinux 2017.2). Not sure which is the best method : the system-user.dtsi or the bootargs in the config menu (never tried this last one)
desulmelionel
 Passing the argument in the config -c kernel. Doesnt let the uio show up in dev.
system-user.dtsi file should look like this.
chosen {
&axilinuxinterface_0{
hanni_xu
hi,your code is very useful for me,but I don't understand one line:
what does it do ? and why?
aripod
That waits for the interrupt to happen
joancab
"That waits for the interrupt to happen"
An interrupt is not something you wait for.
