Participant eduardoparra
Custom IP driver interrupt
I have created a custom IP on my hw design on Vivado. The custom ip has 10 interrupts connected to the pl_ps interrupt port on the Zynq using a Concat block. I'm working on Linux so now i need to create a kernel module and a node on the device tree that allow me to get the interrupts signals. Firstly i have create a default driver using the template of petalinux-create module and i have add a node on the pl dtsi with the region of the ip core, but i have no idea of what to do next. Is there any tutorial or could you tell me how to get those interrupts?
Thank you
Re: Custom IP driver interrupt
you can check these resources
https://www.xilinx.com/support/answers/51138.html
https://www.xilinx.com/support/answers/50572.html
https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
https://www.xilinx.com/support/documentation/ip_documentation/processing_system7/v4_00_a/ds871_processing_system7.pdf
Thanks and Regards
Balkrishan
Observer edu30692
I have create a kernel module to control GPIO leds. I'm working on an zcu102+ evaluation board. This is my device tree:
    amba_pl: amba_pl {
        #address-cells = <2>;
        #size-cells = <2>;
        compatible = "simple-bus";
        ranges ;
        axi_gpio_0: gpio@80000000 {
            #gpio-cells = <2>;
            #interrupt-cells = <2>;
            compatible = "xlnx,custom-gpio";
            gpio-controller ;
            interrupt-controller ;
            interrupt-parent = <&gic>;
            interrupts = <0 89 0>;
            reg = <0x0 0x80000000 0x0 0x10000>;
            xlnx,all-inputs = <0x0>;
            xlnx,all-inputs-2 = <0x0>;
            xlnx,all-outputs = <0x1>;
            xlnx,all-outputs-2 = <0x0>;
            xlnx,dout-default = <0x00000000>;
            xlnx,dout-default-2 = <0x00000000>;
            xlnx,gpio-width = <0x8>;
            xlnx,gpio2-width = <0x20>;
            xlnx,interrupt-present = <0x1>;
            xlnx,is-dual = <0x0>;
            xlnx,tri-default = <0xFFFFFFFF>;
            xlnx,tri-default-2 = <0xFFFFFFFF>;
I have written a device driver an i can turn on /off the leds of my board, but the interrupt on /proc/interrupts does not increase:
           CPU0       CPU1       CPU2       CPU3
  1:          0          0          0          0     GICv2  29 Edge      arch_timer
  2:       8225       8626       7774       6971     GICv2  30 Edge      arch_timer
 12:          0          0          0          0     GICv2 156 Level     zynqmp-dma
 13:          0          0          0          0     GICv2 157 Level     zynqmp-dma
 14:          0          0          0          0     GICv2 158 Level     zynqmp-dma
 15:          0          0          0          0     GICv2 159 Level     zynqmp-dma
 16:          0          0          0          0     GICv2 160 Level     zynqmp-dma
 17:          0          0          0          0     GICv2 161 Level     zynqmp-dma
 18:          0          0          0          0     GICv2 162 Level     zynqmp-dma
 19:          0          0          0          0     GICv2 163 Level     zynqmp-dma
 20:          0          0          0          0     GICv2 164 Level     Mali_GP_MMU, Mali_GP, Mali_PP0_MMU, Mali_PP0, Mali_PP1_MMU, Mali_PP1
198:          0          0          0          0     GICv2  49 Level     cdns-i2c
199:          0          0          0          0     GICv2  50 Level     cdns-i2c
201:          0          0          0          0     GICv2 150 Level     nwl_pcie:misc
206:         15          0          0          0     GICv2  47 Level     ff0f0000.spi
207:          0          0          0          0     GICv2  58 Level     ffa60000.rtc
208:          0          0          0          0     GICv2  59 Level     ffa60000.rtc
209:          0          0          0          0     GICv2 165 Level     ahci-ceva[fd0c0000.ahci]
210:         81          0          0          0     GICv2  81 Level     mmc0
211:          0          0          0          0     GICv2 187 Level     arm-smmu global fault
212:       2267          0          0          0     GICv2  53 Level     xuartps
215:          0          0          0          0     GICv2 154 Level     fd4c0000.dma
216:          0          0          0          0     GICv2 121 Edge      GPIO_AXI_driver
227:          0          0          0          0     GICv2  97 Level     xhci-hcd:usb1
The irq of the axi_gpio on Vivado is connected to the pl_ps_irq pin of the MPSoC.
What have i to do to get my interrupt working?
I have upload the kernel module without format because it doesn't allow to me.
