Custom memory mapping zcu102
Hi all,
I'm adding a memory to the zynq ultrascale board on FNC pins.
I created a boot linux with the bitstream.
I successfully access that memory through a terminal when using the devmem command, accessing the memory with its axi address.
Now, I want my memory to be under the /dev file, like an sd card, and transfer any files on it.
How can I do that ?
best regards
No answer ?
