Custom peripheral memory map in kernel?
I have a somewhat strange problem:
I need to access a custom peripheral from the kernel, more specifically through an "undefined instruction" handler in arch/arm/kernel/traps.c . This is because my peripheral is a coprocessor, so I would like to call it up when CDP instructions are executed.
Problem is, how can I access the memory? The usual way, mmap, does not work, and when I try "ioremap" it causes a kernel panic....
Michele
i've a similar problem... has anyone solved?
