Custom u-boot in PetaLinux
Hello!
I am new to PetaLinux development and running into an issue trying to use custom u-Boot source.
I am following the instructions from here:  http://www.wiki.xilinx.com/PetaLinux+Getting+Started
It tells me to place new source to <PROJECT_ROOT>/components/
linux-host> git clone git://github.com/Xilinx/u-boot-xlnx.git
linux-host> cd u-boot-xlnx
I checked out xilinx version of uBoot and placed it in components/u-boot/u-boot-xlnx
I then ran petalinux-config and selected u-boot-xlnx as my new u-boot source.
When I run petalinux-build I get an error though:
[localhost Avnet-Digilent-ZedBoard-2014.4]$ petalinux-build -c u-boot
INFO: Checking component...
INFO: Generating make files and build linux/u-boot
INFO: Generating make files for the subcomponents of linux/u-boot
INFO: Building linux/u-boot
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[ERROR] make[3]: *** [zynq_zc70x_defconfig] Error 1
[ERROR] make[2]: *** [zynq_zc70x_config] Error 2
[ERROR] make[1]: *** [sub-make] Error 2
ERROR: Failed to build linux/u-boot
build/build.log contains the following lines:
[ALL ] make[2]: Entering directory `/home/axion/Avnet-Digilent-ZedBoard-2014.4/
build/linux/u-boot/u-boot-xlnx'
[ALL ] GEN ./Makefile
[ALL ] drivers/Kconfig:3: can't open file "drivers/core/Kconfig"
[ALL ] make[2]: Leaving directory `/home/axion/Avnet-Digilent-ZedBoard-2014.4/b
[ALL ] make[1]: Leaving directory `/home/axion/Avnet-Digilent-ZedBoard-2014.4/b
uild/linux/u-boot/src/u-boot-xlnx'
[ALL ] make: *** [/home/axion/Avnet-Digilent-ZedBoard-2014.4/build/linux/u-boot
/u-boot-xlnx/include/config.h] Error 255
[ALL ] make: Leaving directory `/home/axion/Avnet-Digilent-ZedBoard-2014.4/buil
d/linux/u-boot'
Apparently u-boot source was never copied to <PROJECT_ROOT>/build folder.  Is there anything else I should do?
I'd like to be able to use petalinux tools (petalinux-build, petalinux-package, etc.) since it is very straight-forward.  Plus it is very convenient to have configuration files in subsustems/linux/configs
Thank you very much.
Welcome to embedded Linux!  the instructions you're following are for build-from-scratch Linux, not PetaLinux.  Both are valid ways to build Linux but they are not equivalent.  For PetaLinux to build a custom U-Boot, specify the Git repository you'd like to use in the top-level configuration (eg, "petalinux-config" at the terminal prompt) rather than downloading on your own as you did here.
this space intentionally left blank
Petalinux will do all the heavy lifting for you with respect to aquiring the source files and compiling them.  I found this tutorial pretty useful for creating a baseline sytem.
ug1156-petalinux-tools-workflow-tutorial.pdf
After you get a baseline system up and running, to change the source for say u-boot, go this directory in your petalinux installation and edit the code that you want to change.
{PETALINUX_INSTALLATION}/petalinux-v2014.4-final/components/u-boot/u-boot-plnx
Then, you can try it out by issuing the following commands.  When you ask petalinux to re-build it pulls differences from the installation directory mentioned.
petalinux-build -c u-boot -x mrproper
petalinux-boot --jtag --u-boot
Nathan
Thank you!
However, I run into the same problem when I exectue petalinux-build -c u-boot
[axion@localhost u-boot-xlnx]$ petalinux-build -c u-boot
INFO: Checking if the remote url is a valid git remote repository!
INFO: Fetching remote component u-boot
Cloning into '/home/axion/Avnet-Digilent-ZedBoard-2014.4/build/linux/u-boot/download/u-boot-xlnx'...
remote: Counting objects: 11271, done.
remote: Compressing objects: 100% (9828/9828), done.
remote: Total 11271 (delta 1749), reused 5145 (delta 1093), pack-reused 0
Receiving objects: 100% (11271/11271), 13.39 MiB | 325.00 KiB/s, done.
Resolving deltas: 100% (1749/1749), done.
From build.log:
[ALL ] make O=/home/axion/Avnet-Digilent-ZedBoard-2014.4/build/linux/u-boot/u-b
oot-xlnx -C /home/axion/Avnet-Digilent-ZedBoard-2014.4/build/linux/u-boot/src/u-
boot-xlnx -j2 zynq_zc70x_config || exit 255
[ALL ] make[1]: Entering directory `/home/axion/Avnet-Digilent-ZedBoard-2014.4/
build/linux/u-boot/src/u-boot-xlnx'
[ALL ] HOSTCC scripts/basic/fixdep
[ALL ] HOSTCC scripts/kconfig/conf.o
[ALL ] SHIPPED scripts/kconfig/zconf.tab.c
[ALL ] SHIPPED scripts/kconfig/zconf.lex.c
[ALL ] SHIPPED scripts/kconfig/zconf.hash.c
[ALL ] HOSTCC scripts/kconfig/zconf.tab.o
[ALL ] HOSTLD scripts/kconfig/conf
d/linux/u-boot'
drivers/Kconfig file does contain a line 'source "drivers/core/Kconfig"' however, there is no folder named 'core' in under u-boot-xlnx/drivers
I have the same problem with the external u-boot from github. I downloaded it from github and changed the u-boot in petalinux-config. Also I changed the custom target in petalinux-config to zynq_zed, but the problem still remains.
Maybe someone can help us ;)
To me this looks ilke a bug in the toolchain not copying over the source files. As a workaround what I did was to simply run it once, then let it fail. Then copy the source files over manually once the directory is in place
So...
cd build/linux/u-boot/u-boot-xlnx/source
rm *
cp -r <directory you have your u-boot checked out to>/u-boot-xlnx/* .
then
hopefully this gets fixed in 2015.2, which should be out pretty soon.
