DMA driver problem
Hi all:
I'm learning DMA through http://www.wiki.xilinx.com/DMA+Drivers+-+Soft+IPs,my question is how to do this step:
After successful compiling and loading the Microblaze/Zynq on to the target, we see the driver probe succesful log as shown,
xilinx-dma 40400000.axidma: Probing xilinx axi dma engine
and this step:
Running the test client will display the message when test is successful,
dmatest: Started 1 threads using dma0chan0 dma0chan1
dma0chan0-dma0c: terminating after 5 tests, 0 failures (status 0)
Chenbing
回复: DMA driver problem
type "dmesg | grep axidma" on a console.
Maybe i didn't express clearly,i have compiled and loaded the Microblaze/Zynq on to the target,,i don't konw how to do this,just input xilinx-dma 40400000.axidma?
thanks
Chenbing
