DMA proxy driver runs once but subsquently continuously times out
Hi everyone!
I have been implementing the proxy driver described in this tutorial. I am using slightly different hardware (built in Vivado 2018.3) Zynq 7000 (ZC702 dev board), and Linux 4.19, built by Petalinux 2019.1.
My system-user dts file has been modified to the following:
/include/ "system-conf.dtsi"
	dma_prox {
		compatible ="xlnx,dma_proxy";
		dmas = <&axi_dma_0 0
			&axi_dma_0 1>;
		dma-names = "dma_proxy_tx", "dma_proxy_rx";
	axidmatest_1: axidmatest@1 {
		compatible ="xlnx,axi-dma-test-1.00.a";
			&axi_dma_0 1>;
		dma-names = "axidma0", "axidma1";
Symptoms:
  • I can successfully run both the axidmatest module in the kernel, and the dma-proxy-test userspace code provided in the tutorial
  • Once the dma-proxy-test has been run once, both TX and RX will consistently fail and time out
  • If, after running the test once, I remove the dma-probe module and add it back, I can run again without error.
  • If I run twice--once successfully, then once with timeouts--I cannot rerun successfully by removing and then adding the module any longer.
  • When the module is activated, the following message appears:
    dma_proxy module initialized
    Allocating uncached memory at virtual address 0x(ptrval), physical address 0x(ptrval)
I have spent a significant amount of time playing with and looking at both the codes of the module and its testing script, but haven't been able to fix this problem. I have very little experience dealing with drivers, so this could potentially be a trivial problem.
I would greatly appreciate your inputs and would be more than happy to provide more details.
Thank you for reading!
回复: DMA proxy driver runs once but subsquently continuously times out
I have the same problems  , do you know how to  sovel  it  ?
I have the same issue.
Always Online
This can be fixed by commenting out the line highlighted beow in the DMA client:
/* Close the file and there's nothing to do for it
static int release(struct inode *ino, struct file *file)
                struct dma_proxy_channel *pchannel_p = (struct dma_proxy_channel *)file->private_data;
                struct dma_device *dma_device = pchannel_p->channel_p->device;
                /* Stop all the activity when the channel is closed assuming this
                * may help if the application is aborted without normal closure
                /*dma_device->device_terminate_all(pchannel_p->channel_p);*/
                return 0;
Always Online
