Observer leroyworld1
DMA: unable to read dma-channels property
I'm trying to get DMA working and I'm getting the following error message when Linux boots up:
xilinx-dma 40400000.dma: unable to read dma-channels property
xilinx-dma 40400000.dma: Probing channels failed
xilinx-dma: probe of 40400000.dma failed with error -22
I'm using:
> Vivado 2015.2
> Device-tree-xlnx-xilinx-v2015.2 (also tried last version and the same happens)
> Last linux-xlnx repository (Kernel version: Linux 4.4.0-xilinx-34440-g5c4698a-dirty)
> PL design is a looped DMA.
When SDK autogenerates the device tree, the file pl.dtsi looks like:
	amba_pl: amba_pl {
		#address-cells = <1>;
		#size-cells = <1>;
		compatible = "simple-bus";
		ranges ;
		axi_dma_0: dma@40400000 {
			compatible = "xlnx,axi-dma";
			interrupt-parent = <&intc>;
			interrupts = <0 29 4 0 30 4>;
			reg = <0x40400000 0x10000>;
			dma-channel@40400000 {
				compatible = "xlnx,axi-dma-mm2s-channel";
				interrupts = <0 29 4>;
				xlnx,datawidth = <0x20>;
				xlnx,device-id = <0x0>;
			dma-channel@40400030 {
				compatible = "xlnx,axi-dma-s2mm-channel";
				interrupts = <0 30 4>;
Any idea? Shouldn't the device-tree generator do this right?
Regards.
Re: DMA: unable to read dma-channels property
The devicetree below works for me. I am using the master xilinx kernel from their Git repository. The last part (dmatest_0) is the trick to make it work.
	amba_pl: amba_pl {
		#size-cells = <1>;
		ranges ;
			compatible = "xlnx,axi-dma-1.00.a";
			#dma-cells = <1>;
		dmatest_0: dmatest@0 {
			compatible ="xlnx,axi-dma-test-1.00.a";
			dmas = <&axi_dma_0 0
				&axi_dma_0 1>;
			dma-names = "axidma0", "axidma1";
Scholar sampatd
I suggest that you try with 2015.4 tag of device tree.
Also, you can verify the axi dma node entry here:
http://www.wiki.xilinx.com/DMA+Drivers+-+Soft+IPs
If I use the axi dma node entry from the wiki or the autogenerated one, with: compatible = "xlnx,axi-dma";      --> nothing happens.
When I change to: compatible = "xlnx,axi-dma-1.00.a";  ---> The output error from my previous post appears.
I enabled dmatest in linux kernel config:
And my design is:
I almost got it. Just something is missing and I don't know what :(
PS: I think there is a typo in device tree node from the WIKI:
dma-channel@40030030   # should be @40400030
Update:
After I read this thread, I decided to downgrade my kernel to 3.17 and I think it finally worked:
xilinx-dma 40400000.axidma: Probing xilinx axi dma engine...Successful
dmatest: Started 1 threads using dma1chan0 dma1chan1
xilinx_dma_start_transfer::simple DMA mode
dma1chan0-dma1c: terminating after 5 tests, 0 failures (status 0)
Now I guess I'll use one of the axidma driver wrappers or create my own.
It'd be great to work with kernel 4.4. But I can't get the suggestions given on that thread to work.
Could @dirk_intersoft, @fanat9 or any other user share a working device-tree for a kernel over 4.0? I'd really appreciate it. :)
Node below works for me for xlnx-4.0. I'm using only one channel in this case, SG mode enabled in hardware design and address not typical:
x0_dma: dma@42e00000 {
	#dma-cells = <1>;
	reg = <0x42e00000 0x10000>;
	xlnx,include-sg = <1>;
	dma-channel@42e00030 {
		xlnx,include-dre = <0>;
		xlnx,datawidth = <32>;
Thanks for your answer fanat9,
I'm still getting the error with kernel 4.4 though:
I'll try to work with v3.17 as long as I don't find a solution for this.
Regards.
Try with 4.0 first.  Btw I'm using Vivado 2015.4 for my hardware design.
And why u have to use 4.4 ?
Yeah, where is a recent patch in xilinx kernel tree which adds multi-channel support and device-tree well be different. Not sure if changes complete and well tested. Use on your own or stick to xlnx 4.0
https://github.com/Xilinx/linux-xlnx/commit/36f9f5546ee2897e20448ae182ae80f1bd689289
Until you asked I didn't know why. I guess just a matter of self-pride, lol. You are right, I don't need it.
Thanks for the patch, but one channel should do for our application, we just need 32 MBytes/s from PL to PS.
As developing my own drivers sounds difficult (I'm a noob with Linux), I'm going to start trying bmartini wrapper for axidma driver, but I gladly accept any other easier suggestions, if any.
Regards.
	amba_pl: amba_pl {
		#size-cells = <1>;
		ranges ;
			#dma-cells = <1>;
				&axi_dma_0 1>;
