DNS with static ip Petalinux 2019.1
I'm trying to understand how to get the DNS working in Petalinux 2019.1 (Zynq 7030) when using a static IP. By default it uses DHCP, but allows the user to configure a static IP address, by modifying /etc/network/interfaces. This works fine, except for the DNS. Adding nameservers entries to this config file does nothing:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
        address 192.x.y.z
        broadcast 192.x.y.255
        netmask 255.255.255.0
        gateway 192.x.y.z
        # this
        dns-nameservers 8.8.8.8 8.8.4.4
        # or this:
        dns-nameserver 8.8.8.8
# or this
# or this
# doesn't do anything
Also I can modify resolv.conf, which works, but only for as long as the OS is running. After restart this is cleared. I can see /etc/resolv.conf is actually symbolically linked to /var/run/resolv.conf. Why this is I'm not sure. I'm also not sure what application overwrites this file.
So my question is, how can I add a DNS server in a persistent way in a Petalinux 2019.1 distribution
I've looked at the following resources, but they do not solve this issue:
https://forums.xilinx.com/t5/Embedded-Linux/DNS-not-working-with-static-IP/m-p/868543#M26982
https://unix.stackexchange.com/questions/323446/file-etc-resolv-conf-deleted-on-every-reboot-why-or-what
Thanks!
Cheers,
Vincent
Re: DNS with static ip Petalinux 2019.1
Ok, so the problem is as follows: Petalinux 2019.1 maps the resolv.conf into RAM FS. Normally udhcpd would fill this file with whatever comes from the dhcp server. However, when using a static IP, this is not the case.
The fix I made works as follows. Each time ifup is run a scriipt checks whether or not the resolv.conf file is empty. If so it copies the content of resolve.conf.static into this file.
I turned this in a yocto file as follows:
File: <petalinux_root>/project-spec/meta-user/recipes-core/base-files/base_files_%.bbappend
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
SRC_URI += " \
        file://001fixdns \
RDEPENDS_${PN} += "bash"
do_install_append() {
    install -d ${D}${sysconfdir}/network/if-up.d
    install -m 0755 ${WORKDIR}/001fixdns ${D}${sysconfdir}/network/if-up.d
File: <petalinux_root>/project-spec/meta-user/recipes-core/base-files/files/001fixdns
#!/bin/bash
if [ ! -s /etc/resolv.conf ] && [ -f /etc/resolv.conf.static ]
then
        cat /etc/resolv.conf.static > /etc/resolv.conf
fi
Its the best I could come up with. If there are any better suggestions I'm still open to them!
Cheers,
Vincent
SRC_URI += " \
        file://001fixdns \
#!/bin/bash
then
fi
Cheers,
Vincent
