ema1905
DP Display Port Live video to PL
I'm tryng to output the display port live video output without PHY :
  • DisplayPort enabled
  • EMIO output (No physical output pin)
  • No Lanes (= No PSGTR)
  • Custom output to PL
I followed the suggestion of the old posts:
https://forums.xilinx.com/t5/Embedded-Linux/No-LiveVideo-and-dev-fb0-when-monitor-unplugged-from-DP/m-p/876841#M27644
https://forums.xilinx.com/t5/Embedded-Linux/Mali-3D-w-o-DP-PHY/td-p/874085
I've applied the commit mentionet before in config:
CONFIG_SUBSYSTEM_COMPONENT_LINUX__KERNEL_NAME_REMOTE_DOWNLOAD_PATH="git://github.com/Xilinx/linux-xlnx.git;protocol=https"
CONFIG_SUBSYSTEM_COMPONENT_LINUX__KERNEL_NAME_REMOTE_REFERENCE="99c43ab5afc0717cd6bace1a8667df2badc7b082"
I added also the flag "e" tokernel bootargs
setenv bootargs 'console=ttyPS0,115200 earlyprintk root=/dev/nfs nfsroot=10.0.0.1:/tftpboot/nfsroot,tcp ip=10.0.0.2:10.0.0.1:10.0.0.1:255.255.255.0:zynqmp:eth0:off rw video=DP-1:1280x1024@30e'
But if i enable the zynqmp_dpsub: zynqmp-display@fd4a0000 in the device tree:
&zynqmp_dpsub {
    status = "okay";
The kernel hang after ZynqMP DMA driver Probe success without any error.
could you help me?
Thank you
ema1905
I went haead a bit , i was using an older wrong FSBL, I regenerated it from SDK  commented out some lines from SERDES initialization init_serdes function in psu_init.c file:
//status &= serdes_fixcal_code();
//status &= serdes_enb_coarse_saturation();
//status &=  psu_serdes_init_data();
Now the kernel boot up correctly and recognize DisplayPort monitor but when i launch Xorg after loading module fb and /usr/lib/xorg/modules/libfb.so there is a Segmentation fault at address 0x24, below i attacched the  /var/log/Xorg.0.log and the kenrel boot
X.Org X Server 1.19.3
Release Date: 2017-03-15
[    61.660] X Protocol Version 11, Revision 0
[    61.660] Build Operating System: Linux 3.10.0-327.el7.x86_64 x86_64
[    61.660] Current Operating System: Linux NOX_project_Rev03 4.14.0-xilinx-v2018.2 #1 SMP Fr
i Oct 5 11:30:26 CEST 2018 aarch64
[    61.661] Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/nfs nfsroot=10.0
o=DP-1:1280x1024@30e loglevel=15
[    61.661] Build Date: 11 June 2018  06:52:05PM
[    61.661]
[    61.661] Current version of pixman: 0.34.0
[    61.661]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[    61.662] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    61.664] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Apr 24 19:41:16 2103
[    61.686] (==) Using config file: "/etc/X11/xorg.conf"
[    61.686] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    61.692] (==) ServerLayout "ServerLayout0"
[    61.693] (**) |-->Screen "DefaultScreen" (0)
[    61.693] (**) |   |-->Monitor "<default monitor>"
[    61.697] (**) |   |-->Device "ZynqMP"
[    61.698] (==) No monitor specified for screen "DefaultScreen".
        Using a default monitor configuration.
[    61.698] (**) Option "BlankTime" "0"
[    61.698] (**) Option "StandbyTime" "0"
[    61.698] (**) Option "SuspendTime" "0"
[    61.698] (**) Option "OffTime" "0"
[    61.698] (==) Automatically adding devices
[    61.698] (==) Automatically enabling devices
[    61.698] (==) Automatically adding GPU devices
[    61.702] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    61.707] (WW) The directory "/usr/share/fonts/X11/misc/" does not exist.
[    61.707]    Entry deleted from font path.
[    61.708] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
[    61.708]    Entry deleted from font path.
[    61.709] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
[    61.709]    Entry deleted from font path.
[    61.710] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
[    61.710]    Entry deleted from font path.
[    61.711] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    61.711]    Entry deleted from font path.
[    61.712] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    61.712]    Entry deleted from font path.
[    61.713] (==) FontPath set to:
[    61.713] (==) ModulePath set to "/usr/lib/xorg/modules"
[    61.713] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[    61.713] (II) Loader magic: 0x5bfc00
[    61.713] (II) Module ABI versions:
[    61.713]    X.Org ANSI C Emulation: 0.4
[    61.713]    X.Org Video Driver: 23.0
[    61.713]    X.Org XInput driver : 24.1
[    61.713]    X.Org Server Extension : 10.0
[    61.721] (II) xfree86: Adding drm device (/dev/dri/card0)
[    61.724] (II) no primary bus or device found
[    61.724]    falling back to /sys/devices/platform/amba/fd4a0000.zynqmp-display/drm/card0
[    61.725] (II) LoadModule: "glx"
[    61.763] (WW) Warning, couldn't open module glx
[    61.763] (II) UnloadModule: "glx"
[    61.763] (II) Unloading glx
[    61.763] (EE) Failed to load module "glx" (module does not exist, 0)
[    61.763] (II) LoadModule: "armsoc"
[    61.775] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[    61.784] (II) Module armsoc: vendor="X.Org Foundation"
[    61.784]    compiled for 1.19.3, module version = 1.4.1
[    61.784]    Module class: X.Org Video Driver
[    61.784]    ABI class: X.Org Video Driver, version 23.0
[    61.785] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[    61.785] (--) using VT number 2
[    61.786] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[    61.789] (WW) Falling back to old probe method for armsoc
[    61.789] (II) No BusID or DriverName specified - opening /dev/dri/card0
[    61.790] (II) Got BusID fd4a0000.zynqmp-display
[    61.794] (II) Opened DRM
[    61.795] (II)    DeviceName is [/dev/dri/card0]
[    61.795] (II)    bus_id is [fd4a0000.zynqmp-display]
[    61.795] (II)    DriverName is [xlnx]
[    61.795] (II)    version is [1.0.0]
[    61.795] (II) Screen:0,  CRTC:-1
[    61.796] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    61.796] (II) ARMSOC(0): Creating default Display subsection in Screen section
        "DefaultScreen" for depth/fbbpp 24/32
[    61.796] (++) ARMSOC(0): Depth 24, (--) framebuffer bpp 32
[    61.796] (==) ARMSOC(0): RGB weight 888
[    61.796] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[    61.797] (==) ARMSOC(0): Default visual is TrueColor
[    61.797] (II) No BusID or DriverName specified - opening /dev/dri/card0
[    61.797] (II) Got BusID fd4a0000.zynqmp-display
[    61.801] (II) Opened DRM
[    61.802] (II)    DeviceName is [/dev/dri/card0]
[    61.802] (II)    bus_id is [fd4a0000.zynqmp-display]
[    61.802] (II)    DriverName is [xlnx]
[    61.802] (II)    version is [1.0.0]
[    61.803] (II) ARMSOC(0): Chipset: Mali
[    61.803] (**) ARMSOC(0): Option "Debug" "false"
[    61.804] (**) ARMSOC(0): Option "DRICard" "0"
[    61.804] (II) ARMSOC(0): Buffer Flipping is Enabled
[    61.804] (II) ARMSOC(0): umplock is Enabled
[    61.804] (II) ARMSOC(0): Setting the video modes ...
[    61.804] (II) ARMSOC(0): Adding all CRTCs
[    61.804] (II) ARMSOC(0): Got CRTC: 0 (id: 36)
[    61.804] (WW) ARMSOC(0): No outputs definitely connected, trying again...
[    61.805] (WW) ARMSOC(0): Unable to find connected outputs - setting 1024x768 initial frame
buffer
[    61.805] (II) ARMSOC(0): Got KMS resources
[    61.805] (==) ARMSOC(0): DPI set to (96, 96)
[    61.805] (II) Loading sub module "dri2"
[    61.805] (II) LoadModule: "dri2"
[    61.805] (II) Module "dri2" already built-in
[    61.805] (II) Loading sub module "exa"
[    61.805] (II) LoadModule: "exa"
[    61.822] (II) Loading /usr/lib/xorg/modules/libexa.so
[    61.831] (II) Module exa: vendor="X.Org Foundation"
[    61.831]    compiled for 1.19.3, module version = 2.6.0
[    61.832]    ABI class: X.Org Video Driver, version 23.0
[    61.832] (II) Loading sub module "fb"
[    61.832] (II) LoadModule: "fb"
[    61.836] (II) Loading /usr/lib/xorg/modules/libfb.so
[    61.846] (II) Module fb: vendor="X.Org Foundation"
[    61.846]    compiled for 1.19.3, module version = 1.0.0
[    61.846]    ABI class: X.Org ANSI C Emulation, version 0.4
[    61.846] (EE)
[    61.847] (EE) Backtrace:
[    61.847] (EE) 0: /usr/bin/Xorg (xorg_backtrace+0x48) [0x56ec70]
[    61.847] (EE)
[    61.848] (EE) Segmentation fault at address 0x24
[    61.848] (EE)
Fatal server error:
[    61.848] (EE) Caught signal 11 (Segmentation fault). Server aborting
[    61.848] (EE)
[    61.848] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[    61.849] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional infor
mation.
[    61.849] (EE)
[    61.852] (EE) Server terminated with error (1). Closing log file.
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-xilinx-v2018.2 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP Fri Oct 5 11:30:26 CEST 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: ZynqMP NOX Rev3.0
[    0.000000] cma: Failed to reserve 1000 MiB
[    0.000000] On node 0 totalpages: 454656
[    0.000000]   DMA zone: 6272 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 454656 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 20 pages/cpu @ffffffc06ff71000 s44312 r8192 d29416 u81920
[    0.000000] pcpu-alloc: s44312 r8192 d29416 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 448384
[    0.000000] Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/nfs nfsroot=10.0.0.1:/tftpboot/nfsroot,tcpip=10.0.0.2:10.0.0.1:10.0.0.1:255.255.255.0:zynqmp:eth0:off rw video=DP-1:1280x1024@30e loglevel=15
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1769844K/1818624K available (9790K kernel code, 634K rwdata, 3108K rodata, 448K init, 2365K bss, 48780K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a10000   (  9792 KB)
[    0.000000]     .rodata : 0xffffff8008a10000 - 0xffffff8008d20000   (  3136 KB)
[    0.000000]       .init : 0xffffff8008d20000 - 0xffffff8008d90000   (   448 KB)
[    0.000000]       .data : 0xffffff8008d90000 - 0xffffff8008e2e808   (   635 KB)
[    0.000000]        .bss : 0xffffff8008e2e808 - 0xffffff800907ddb0   (  2366 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01880000   (    24 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc070000000   (  1792 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq-xilinx: /amba_pl@0/interrupt-controller@80125000: num_irq=14, edge=0x0
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1710236356, max_idle_ns: 440795202549 ns
[    0.000017] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511099ns
[    0.001682] Console: colour dummy device 80x25
[    0.001755] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399999)
[    0.001798] pid_max: default: 32768 minimum: 301
[    0.002326] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002383] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.005064] ASID allocator initialised with 65536 entries
[    0.005303] Hierarchical SRCU implementation.
[    0.007115] zynqmp_plat_init Platform Management API v1.0
[    0.007146] zynqmp_plat_init Trustzone version v1.0
[    0.007721] smp: Bringing up secondary CPUs ...
[    0.282817] Detected VIPT I-cache on CPU1
[    0.282936] CPU1: Booted secondary processor [410fd034]
[    0.531467] Detected VIPT I-cache on CPU2
[    0.531572] CPU2: Booted secondary processor [410fd034]
[    0.766112] Detected VIPT I-cache on CPU3
[    0.766217] CPU3: Booted secondary processor [410fd034]
[    0.766452] smp: Brought up 1 node, 4 CPUs
[    0.766535] SMP: Total of 4 processors activated.
[    0.766564] CPU features: detected feature: 32-bit EL0 Support
[    0.766604] CPU: All CPU(s) started at EL2
[    0.766670] alternatives: patching kernel code
[    0.768929] devtmpfs: initialized
[    0.793005] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.793055] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.793618] xor: measuring software checksum speed
[    0.831384]    8regs     :   384.000 MB/sec
[    0.871564]    8regs_prefetch:   342.000 MB/sec
[    0.911754]    32regs    :   472.000 MB/sec
[    0.951942]    32regs_prefetch:   397.000 MB/sec
[    0.951966] xor: using function: 32regs (472.000 MB/sec)
[    0.952207] pinctrl core: initialized pinctrl subsystem
[    0.954182] NET: Registered protocol family 16
[    0.959678] vdso: 2 pages (1 code @ ffffff8008a16000, 1 data @ ffffff8008d94000)
[    0.959727] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.960351] DMA: preallocated 256 KiB pool for atomic allocations
[    1.061175] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    1.063597] ARM CCI_400_r1 PMU driver probed
[    1.088783] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    1.089979] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249993) is a xuartps
[    1.623067] console [ttyPS0] enabled
[    1.628429] ff010000.serial: ttyPS10 at MMIO 0xff010000 (irq = 43, base_baud = 6249993) is a xuartps
[    1.693841] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.766711] raid6: int64x1  gen()    66 MB/s
[    1.838987] raid6: int64x1  xor()    74 MB/s
[    1.911189] raid6: int64x2  gen()   114 MB/s
[    1.983704] raid6: int64x2  xor()   100 MB/s
[    2.055868] raid6: int64x4  gen()   173 MB/s
[    2.128207] raid6: int64x4  xor()   123 MB/s
[    2.200437] raid6: int64x8  gen()   163 MB/s
[    2.272874] raid6: int64x8  xor()   124 MB/s
[    2.345150] raid6: neonx1   gen()   121 MB/s
[    2.417402] raid6: neonx1   xor()   142 MB/s
[    2.489759] raid6: neonx2   gen()   194 MB/s
[    2.562028] raid6: neonx2   xor()   200 MB/s
[    2.634402] raid6: neonx4   gen()   250 MB/s
[    2.706645] raid6: neonx4   xor()   239 MB/s
[    2.779011] raid6: neonx8   gen()   274 MB/s
[    2.851343] raid6: neonx8   xor()   253 MB/s
[    2.855566] raid6: using algorithm neonx8 gen() 274 MB/s
[    2.860855] raid6: .... xor() 253 MB/s, rmw enabled
[    2.865716] raid6: using neon recovery algorithm
[    2.874965] SCSI subsystem initialized
[    2.878925] libata version 3.00 loaded.
[    2.883397] usbcore: registered new interface driver usbfs
[    2.889005] usbcore: registered new interface driver hub
[    2.894491] usbcore: registered new device driver usb
[    2.899817] media: Linux media interface: v0.10
[    2.904431] Linux video capture interface: v2.00
[    2.909226] pps_core: LinuxPPS API ver. 1 registered
[    2.914158] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.923328] PTP clock support registered
[    2.927328] EDAC MC: Ver: 3.0.0
[    2.931575] FPGA manager framework
[    2.935470] fpga-region fpga-full: FPGA Region probed
[    2.941091] Advanced Linux Sound Architecture Driver Initialized.
[    2.948251] Bluetooth: Core ver 2.22
[    2.951900] NET: Registered protocol family 31
[    2.956309] Bluetooth: HCI device and connection manager initialized
[    2.962651] Bluetooth: HCI socket layer initialized
[    2.967509] Bluetooth: L2CAP socket layer initialized
[    2.972582] Bluetooth: SCO socket layer initialized
[    2.980188] clocksource: Switched to clocksource arch_sys_counter
[    2.986578] VFS: Disk quotas dquot_6.6.0
[    2.990625] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.015928] NET: Registered protocol family 2
[    3.021560] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    3.029362] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    3.037035] TCP: Hash tables configured (established 16384 bind 16384)
[    3.043786] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    3.049968] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    3.056883] NET: Registered protocol family 1
[    3.061958] RPC: Registered named UNIX socket transport module.
[    3.067903] RPC: Registered udp transport module.
[    3.072567] RPC: Registered tcp transport module.
[    3.077250] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.083682] PCI: CLS 0 bytes, default 128
[    3.089819] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    3.097656] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    3.108532] audit: initializing netlink subsys (disabled)
[    3.114195] audit: type=2000 audit(2.848:1): state=initialized audit_enabled=0 res=1
[    3.115684] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    3.131530] NFS: Registering the id_resolver key type
[    3.136613] Key type id_resolver registered
[    3.140759] Key type id_legacy registered
[    3.144768] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.151486] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
[    3.297569] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    3.304950] io scheduler noop registered
[    3.308835] io scheduler deadline registered
[    3.313160] io scheduler cfq registered (default)
[    3.317828] io scheduler mq-deadline registered
[    3.322337] io scheduler kyber registered
[    3.332672] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    3.340780] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    3.348446] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    3.356043] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    3.363661] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    3.371254] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    3.378864] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    3.386483] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    3.394076] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    3.401723] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    3.409316] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    3.416903] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    3.424560] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    3.432144] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    3.439757] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    3.447373] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    3.454983] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    3.578996] Serial: 8250/16550 driver, 11 ports, IRQ sharing disabled
[    3.595042] 80154000.serial: ttyS8 at MMIO 0x80155000 (irq = 49, base_baud = 3375000) is a 16550A
[    3.606343] 80146000.serial: ttyS9 at MMIO 0x80147000 (irq = 50, base_baud = 3375000) is a 16550A
[    3.617323] 80144000.serial: ttyS1 at MMIO 0x80145000 (irq = 51, base_baud = 3375000) is a 16550A
[    3.628267] 80142000.serial: ttyS2 at MMIO 0x80143000 (irq = 52, base_baud = 3375000) is a 16550A
[    3.639113] 80148000.serial: ttyS3 at MMIO 0x80149000 (irq = 53, base_baud = 3375000) is a 16550A
[    3.649987] 80140000.serial: ttyS4 at MMIO 0x80141000 (irq = 54, base_baud = 3375000) is a 16550A
[    3.660902] 80200000.serial: ttyS5 at MMIO 0x80201000 (irq = 55, base_baud = 3375000) is a 16550A
[    3.671958] 80152000.serial: ttyS6 at MMIO 0x80153000 (irq = 63, base_baud = 3375000) is a 16550A
[    3.682769] 80150000.serial: ttyS7 at MMIO 0x80151000 (irq = 64, base_baud = 3375000) is a 16550A
[    3.707973] PLL: shutdown
[    3.710859] PLL: shutdown
[    3.716345] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    3.723730] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.730313] [drm] No driver support for vblank timestamp query.
[    3.736392] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008ac68a8)
[    3.744390] [drm] Cannot find any crtc or sizes
[    3.749397] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[    3.757566] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver proed
[    3.766778] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.794163] brd: module loaded
[    3.813844] loop: module loaded
[    3.821656] mtdoops: mtd device (mtddev=name/number) must be supplied
[    3.832902] m25p80 spi0.0: n25q512a (65536 Kbytes)
[    3.837741] 3 ofpart partitions found on MTD device spi0.0
[    3.843188] Creating 3 MTD partitions on "spi0.0":
[    3.847968] 0x000000000000-0x000000f00000 : "boot"
[    3.854703] 0x000000f00000-0x000001000000 : "bootenv"
[    3.861707] 0x000001000000-0x000001f00000 : "kernel"
[    3.873389] libphy: Fixed MDIO Bus: probed
[    3.883315] tun: Universal TUN/TAP device driver, 1.6
[    3.888689] CAN device driver interface
[    3.895047] macb ff0b0000.ethernet: Not enabling partial store and forward
[    3.903787] libphy: MACB_mii_bus: probed
[    3.910877] macb ff0b0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 31 (00:0a:35:00:22:01)
[    3.920746] Generic PHY ff0b0000.ethernet-ffffffff:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ff0b0000.ethernet-ffffffff:01, irq=POLL)
[    3.938449] usbcore: registered new interface driver asix
[    3.943975] usbcore: registered new interface driver ax88179_178a
[    3.950163] usbcore: registered new interface driver cdc_ether
[    3.956081] usbcore: registered new interface driver net1080
[    3.961827] usbcore: registered new interface driver cdc_subset
[    3.967834] usbcore: registered new interface driver zaurus
[    3.973544] usbcore: registered new interface driver cdc_ncm
[    3.980337] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    3.988717] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.995211] ehci-pci: EHCI PCI platform driver
[    4.001679] usbcore: registered new interface driver cdc_acm
[    4.007300] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.015424] usbcore: registered new interface driver uas
[    4.020864] usbcore: registered new interface driver usb-storage
[    4.029295] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    4.036893] i2c /dev entries driver
[    4.041629] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 33
[    4.048712] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 34
[    4.063568] IR NEC protocol handler initialized
[    4.068087] IR RC5(x/sz) protocol handler initialized
[    4.073148] IR RC6 protocol handler initialized
[    4.077645] IR JVC protocol handler initialized
[    4.082154] IR Sony protocol handler initialized
[    4.086753] IR SANYO protocol handler initialized
[    4.091441] IR Sharp protocol handler initialized
[    4.096128] IR MCE Keyboard/mouse protocol handler initialized
[    4.101942] IR XMP protocol handler initialized
[    4.107042] vivid-000: using single planar format API
[    4.119783] vivid-000: V4L2 capture device registered as video0
[    4.125982] vivid-000: V4L2 output device registered as video1
[    4.132094] vivid-000: V4L2 capture device registered as vbi0, supports raw and sliced VBI
[    4.140784] vivid-000: V4L2 output device registered as vbi1, supports raw and sliced VBI
[    4.149241] vivid-000: V4L2 capture device registered as swradio0
[    4.155618] vivid-000: V4L2 receiver device registered as radio0
[    4.161890] vivid-000: V4L2 transmitter device registered as radio1
[    4.176323] usbcore: registered new interface driver uvcvideo
[    4.182033] USB Video Class driver (1.1.1)
[    4.188641] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff800919d000 with timeout 10s
[    4.198778] Bluetooth: HCI UART driver ver 2.3
[    4.203221] Bluetooth: HCI UART protocol H4 registered
[    4.208322] Bluetooth: HCI UART protocol BCSP registered
[    4.213730] Bluetooth: HCI UART protocol LL registered
[    4.218830] Bluetooth: HCI UART protocol ATH3K registered
[    4.224208] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.230688] Bluetooth: HCI UART protocol Intel registered
[    4.236050] Bluetooth: HCI UART protocol QCA registered
[    4.241434] usbcore: registered new interface driver bcm203x
[    4.247218] usbcore: registered new interface driver bpa10x
[    4.252902] usbcore: registered new interface driver bfusb
[    4.258497] usbcore: registered new interface driver btusb
[    4.263950] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    4.269836] usbcore: registered new interface driver ath3k
[    4.275957] EDAC MC: ECC not enabled
[    4.280336] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    4.290338] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    4.303979] sdhci: Secure Digital Host Controller Interface driver
[    4.310129] sdhci: Copyright(c) Pierre Ossman
[    4.314460] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.321003] PLL: enable
[    4.368258] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    4.420250] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    4.429741] ledtrig-cpu: registered to indicate activity on CPUs
[    4.436402] usbcore: registered new interface driver usbhid
[    4.441951] usbhid: USB HID core driver
[    4.448311] mmc0: new HS200 MMC card at address 0001
[    4.454318] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    4.456900] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    4.460580] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    4.460854] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    4.464678] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    4.466491] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    4.466806] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    4.468339] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[    4.468655] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    4.533920] Netfilter messages via NETLINK v0.30.
[    4.533949] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    4.534349] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    4.534699] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    4.538752]  mmcblk0: p1
[    4.559413] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.567426] Initializing XFRM netlink socket
[    4.571979] NET: Registered protocol family 10
[    4.578470] Segment Routing with IPv6
[    4.582336] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    4.588658] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    4.596076] NET: Registered protocol family 17
[    4.600538] NET: Registered protocol family 15
[    4.604988] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.617911] Ebtables v2.0 registered
[    4.621976] can: controller area network core (rev 20170425 abi 9)
[    4.628362] NET: Registered protocol family 29
[    4.632789] can: raw protocol (rev 20170425)
[    4.637024] can: broadcast manager protocol (rev 20170425 t)
[    4.642677] can: netlink gateway (rev 20170425) max_hops=1
[    4.648752] Bluetooth: RFCOMM TTY layer initialized
[    4.653673] Bluetooth: RFCOMM socket layer initialized
[    4.658913] Bluetooth: RFCOMM ver 1.11
[    4.662735] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.668086] Bluetooth: BNEP filters: protocol multicast
[    4.673355] Bluetooth: BNEP socket layer initialized
[    4.678354] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.684269] Bluetooth: HIDP socket layer initialized
[    4.689786] 9pnet: Installing 9P2000 support
[    4.694052] Key type dns_resolver registered
[    4.700348] registered taskstats version 1
[    4.705957] Btrfs loaded, crc32c=crc32c-generic
[    4.736597] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy
[    4.746675] dwc3 fe200000.dwc3: Configuration mismatch. dr_mode forced to host
[    4.754510] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.760054] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.767997] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
[    4.776779] xhci-hcd xhci-hcd.0.auto: irq 66, io mem 0xfe200000
[    4.783260] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.790037] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.797231] usb usb1: Product: xHCI Host Controller
[    4.802088] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    4.808771] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.814846] hub 1-0:1.0: USB hub found
[    4.818689] hub 1-0:1.0: 1 port detected
[    4.823368] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.828897] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.836782] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.845285] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.852055] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.859248] usb usb2: Product: xHCI Host Controller
[    4.864107] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    4.870789] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.876757] hub 2-0:1.0: USB hub found
[    4.880565] hub 2-0:1.0: 1 port detected
[    4.886286] rtc_zynqmp ffa60000.rtc: setting system clock to 2103-04-24 19:40:28 UTC (4206886828)
[    4.899541] pps pps0: new PPS source ptp0
[    4.903554] macb ff0b0000.ethernet: gem-ptp-timer ptp clock registered.
[    4.910310] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.928485] macb ff0b0000.ethernet eth0: link up (100/Full)
[    5.934059] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    5.952222] IP-Config: Complete:
[    5.955436]      device=eth0, hwaddr=00:0a:35:00:22:01, ipaddr=10.0.0.2, mask=255.255.255.0, gw=10.0.0.1
[    5.964893]      host=zynqmp, domain=, nis-domain=(none)
[    5.970177]      bootserver=10.0.0.1, rootserver=10.0.0.1, rootpath=
[    5.978855] ALSA device list:
[    5.981802]   #0: DisplayPort monitor
[    6.000231] VFS: Mounted root (nfs filesystem) on device 0:16.
[    6.006634] devtmpfs: mounted
[    6.010235] Freeing unused kernel memory: 448K
INIT: version 2.88 booting
Starting udev
[    7.063205] udevd[1827]: starting version 3.2.2
[    7.198263] udevd[1828]: starting eudev-3.2.2
[    7.620711] mali: loading out-of-tree module taints kernel.
[    7.806003] ERROR: could not get clock /amba_pl@0/vcu@80000000:aclk(1)
[    7.812580] xilinx-vcu a0040000.vcu: Could not get aclk clock
[    7.818367] xilinx-vcu: probe of a0040000.vcu failed with error -2
[    9.603921] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   10.643726] random: crng init done
Starting internet superserver: inetd.
INIT: Entering runlevel: 5
Configuring network interfaces... RTNETLINK answers: File exists
ifup skipped for nfsroot interface eth0
run-parts: /etc/network/if-pre-up.d/nfsroot: exit status 1
Starting system message bus: dbus.
Starting Dropbear SSH server: dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
Setting console loglevel to 0 ...
root@NOX_project_Rev03:~# which: no tricube in (/media/card:/media/card/bin:/usr/local/bin:/us
r/bin:/bin)
ema1905
I noticed that under  /sys/class/drm/ i have only:
card0/      version
Instead of
card0/      card0-DP-1/ controlD64/ version
it seems that  card0-DP-1 is not probed well but i don't have any error or warning during kernel boot, where can i check it?
ema1905
i enabled the drm debug with kernel bootargs:
drm.debug=0x2f drm_kms_helper.fbdev_emulation=false
[    1.904975] [drm:drm_core_init] Initialized
[    1.905429] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.905429] [drm] No driver support for vblank timestamp query.
[    1.905434] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008b37868)
[    1.905436] [drm:drm_setup_crtcs]
[    1.905437] [drm:drm_setup_crtcs] No connectors reported connected with modes
[    1.905438] [drm:drm_setup_crtcs] picking CRTCs for 4096x4096 config
[    1.905438] [drm] Cannot find any crtc or sizes
[    1.905439] [drm:drm_minor_register]
[    1.905440] [drm:drm_minor_register]
[    1.905452] [drm:drm_minor_register] new minor registered 0
[    1.905454] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[   19.772557] [drm:drm_stub_open]
[   19.772600] [drm:drm_open] pid = 2293, minor = 0
[   19.772633] [drm:drm_open]
[   19.773157] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_VERSION
[   19.773209] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_VERSION
[   19.773298] [drm:drm_release] open_count = 1
[   19.773325] [drm:drm_release] pid = 2293, device = 0xe200, open_count = 1
[   19.773358] [drm:drm_lastclose]
[   19.773378] [drm:drm_lastclose] driver lastclose completed
[   19.775705] [drm:drm_stub_open]
[   19.775737] [drm:drm_open] pid = 2293, minor = 0
[   19.775765] [drm:drm_open]
[   19.775831] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_SET_VERSION
[   19.775877] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_GET_UNIQUE
[   19.775917] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_GET_UNIQUE
[   19.776026] [drm:drm_release] open_count = 1
[   19.776053] [drm:drm_release] pid = 2293, device = 0xe200, open_count = 1
[   19.776083] [drm:drm_lastclose]
[   19.776104] [drm:drm_lastclose] driver lastclose completed
[   19.779703] [drm:drm_stub_open]
[   19.781317] [drm:drm_stub_open]
[   19.784732] [drm:drm_stub_open]
[   19.786311] [drm:drm_stub_open]
[   19.789772] [drm:drm_stub_open]
[   19.791437] [drm:drm_stub_open]
[   19.794602] [drm:drm_stub_open]
[   19.796229] [drm:drm_stub_open]
[   19.799585] [drm:drm_stub_open]
[   19.801169] [drm:drm_stub_open]
[   19.804357] [drm:drm_stub_open]
[   19.805939] [drm:drm_stub_open]
[   19.809122] [drm:drm_stub_open]
[   19.810704] [drm:drm_stub_open]
[   19.813896] [drm:drm_stub_open]
[   19.815552] [drm:drm_stub_open]
[   19.818720] [drm:drm_stub_open]
[   19.820317] [drm:drm_stub_open]
[   19.823508] [drm:drm_stub_open]
[   19.825197] [drm:drm_stub_open]
[   19.828735] [drm:drm_stub_open]
[   19.830375] [drm:drm_stub_open]
[   19.833826] [drm:drm_stub_open]
[   19.835596] [drm:drm_stub_open]
[   19.839028] [drm:drm_stub_open]
[   19.840754] [drm:drm_stub_open]
[   19.844265] [drm:drm_stub_open]
[   19.846011] [drm:drm_stub_open]
[   19.849389] [drm:drm_stub_open]
[   19.851156] [drm:drm_stub_open]
[   19.853370] [drm:drm_stub_open]
[   19.853403] [drm:drm_open] pid = 2293, minor = 0
[   19.853432] [drm:drm_open]
[   19.853487] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_VERSION
[   19.853531] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_VERSION
[   19.853598] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_GET_UNIQUE
[   19.853635] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_GET_UNIQUE
[   19.853693] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_SET_CLIENT_CAP
[   19.853735] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETRESOURCES
[   19.853775] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETRESOURCES
[   19.853840] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETCRTC
[   19.853895] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[   19.853950] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[   19.854019] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854063] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854122] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854158] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854199] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854234] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854274] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854309] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854359] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPLANERESOURCES
[   19.854394] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPLANERESOURCES
[   19.854440] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPLANE
[   19.854478] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPLANE
[   19.854521] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPLANE
[   19.854557] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPLANE
[   19.854599] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[   19.854649] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[   19.854705] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854744] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854790] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854824] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.854954] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[   19.855031] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[   19.855124] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.855215] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.855293] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.855356] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.855432] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.855495] [drm:drm_ioctl] pid=2293, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[   19.857307] [drm:drm_release] open_count = 1
[   19.857337] [drm:drm_release] pid = 2293, device = 0xe200, open_count = 1
[   19.857367] [drm:drm_lastclose]
[   19.857388] [drm:drm_lastclose] driver lastclose completed
shcohen1974
Hi I have the same probplem :(
Did you find the solution?
Can you share it, please?
