DP Display - pll lock failed | MPSoC device
Dear all,
I hope all are doing great.
I am having the problem to enable the DP display interface on my custom MPSoC device. I have build the project with the following project configuration.
Environment:
Xilinx Vivado 2019.2
Xilinx petaLinux 2019.2
Vivado DP configuration
Petalinux configuration
Kernel Configuration:
CONFIG_XILINX_DPDMA=y
CONFIG_CMA=y
CONFIG_DMA_CMA=y
CONFIG_CMA_SIZE_MBYTES=256
CONFIG_DRM_XLNX=y
CONFIG_DRM_XLNX_BRIDGE=y
CONFIG_DRM_XLNX_BRIDGE_DEBUG_FS=y
CONFIG_DRM_ZYNQMP_DPSUB=y
Reference link:-
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842105/ZynqMP+DisplayPort+Linux+driver
system-user.dtsi
&zynqmp_dpsub {
phy-names = "dp-phy0","dp-phy1";
phys = <&lane1 6 0 1 27000000>, <&lane0 6 1 1 27000000>;
status = "okay";
xlnx,max-lanes = <2>;
&xlnx_dpdma {
status = "okay";
Problem
while booting the board I can see that DP port configuration is failing with the below log.
[ 4.341781] xilinx-psgtr fd400000.zynqmp_phy: PLL lock time out
[ 4.347703] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:no
[ 4.355443] zynqmp-display fd4a0000.zynqmp-display: failed to lock pll
[ 4.361982] zynqmp-display: probe of fd4a0000.zynqmp-display failed with error -110
It will be highly appreciated if anyone could help to address this issue?
Re: DP Display - pll lock failed | MPSoC device
does anybody have any suggestions on this issue?
Hi all,
Can anyone help me to work around the above issue?
Mentor
Mentor
Hi @deepg799
Where is your video source ?
Did you make sure whether video source is proper or not ?
Refer the following document.
https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf#page=958
Hi @watari
Thanks for the update.
Yes, I make sure that my video source (DP monitor) is coming connected properly.
In the booting log I can see the error message shown below:
[15.100543] xilinx-psgtr fd400000.zynqmp_phy: PLL lock time out
[15.100543] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:no
[15.108284] zynqmp-display fd4a0000.zynqmp_phy: PLL lock time out
[15.114824] zynqmp-display: probe of fd4a0000.zynqmp-display failed with error -110
The same petalinux and vivado configuration is working fine in 2018.3 tool version.
Mentor
Mentor
Hi @deepg799
No. DP monitor is sink device. I ask you where is your video source module to make sure connection and so on in MPSoC ?
ex. Your own designed VTC with video signal and it goes out through dp live video...
Would you make sure source clock setting to this PLL and connection to zynqmp_phy, too ?
Hi @watari
here nothing is involved in PL side related to DP source. We are testing the PS DP interface.
Below is the screenshot for the output clock configuration, and you can also find the I/P clock configuration as shown above diagram.
The same i/p and o/p clock configuration I made in 2018.3 and it is working fine. please let me know if I missed any information here.
Thank you in advance
@watari
For your reference also attaching the vivado BD design.
Mentor
Mentor
Hi @deepg799
I confirmed boot log file and bd file and so on.
It seems wrong clock setting in dtb file.
Would you make sure device tree or share it ?
Hi @watari
Attaching the system.dtsi, pcw.dtsi and system.dts file
Hi @watari
Yes, I think you are right it is a problem with device tree configuration. because I removed the device tree from the working project and I met with the same error. That means In this project also device tree is not configured properly.
Could you please guide me to configure it properly?
Thanks in advance.
Mentor
Mentor
Hi @deepg799
Would you make sure connection and parameter abbout dp_vtc_pixel_clk_in ?
Unfortunately since I didn't have enough information about your design, I couldn't investigate the route cause.
But I suspect "dp_vtc_pixel_clk_in".
