Participant ohmmaxma007
DPU Tutorial 2019.1
I'm use petalinux 2019.1 & Vivado 2019 on Ubuntu 18.04 i'm try to test yocto project on Avnet ultra96-v2 from
(Link)
but i'm create hdf file from vivado and edit ip dpu for setting in my work
In build step it's error because recipe-support opencv3.1 cannot run on petalinux 2019.1
[INFO] building project
[INFO] generating Kconfig for project
[INFO] silentconfig project
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating machine configuration
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating user layers
[INFO] generating kconfig for Rootfs
[INFO] silentconfig rootfs
[INFO] generating petalinux-user-image.bb
INFO: bitbake petalinux-user-image
WARNING: /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/project-spec/meta-user/recipes-support/opencv/opencv_3.1.bb: Exception during build_dependencies for cmake_do_configure
WARNING: /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/project-spec/meta-user/recipes-support/opencv/opencv_3.1.bb: Error during finalise of /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/project-spec/meta-user/recipes-support/opencv/opencv_3.1.bb
ERROR: ExpansionError during parsing /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/project-spec/meta-user/recipes-support/opencv/opencv_3.1.bb
Traceback (most recent call last):
bb.data_smart.ExpansionError: Failure expanding variable EXTRA_OECMAKE, expression was -DOPENCV_EXTRA_MODULES_PATH=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/aarch64-xilinx-linux/opencv/3.1+gitAUTOINC+92387b1ef8-r0/contrib/modules     -DWITH_1394=OFF     -DCMAKE_SKIP_RPATH=ON     -DOPENCV_ICV_PACKAGE_DOWNLOADED=808b791a6eac9ed78d32a7666804320e     -DOPENCV_ICV_PATH=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/aarch64-xilinx-linux/opencv/3.1+gitAUTOINC+92387b1ef8-r0/ippicv_lnx     ${@bb.utils.contains("TARGET_CC_ARCH", "-msse3", "-DENABLE_SSE=1 -DENABLE_SSE2=1 -DENABLE_SSE3=1 -DENABLE_SSSE3=1", "", d)}     ${@bb.utils.contains("TARGET_CC_ARCH", "-msse4.1", "-DENABLE_SSE=1 -DENABLE_SSE2=1 -DENABLE_SSE3=1 -DENABLE_SSSE3=1 -DENABLE_SSE41=1", "", d)}     ${@bb.utils.contains("TARGET_CC_ARCH", "-msse4.2", "-DENABLE_SSE=1 -DENABLE_SSE2=1 -DENABLE_SSE3=1 -DENABLE_SSSE3=1 -DENABLE_SSE41=1 -DENABLE_SSE42=1", "", d)}     ${@base_conditional("libdir", "/usr/lib64", "-DLIB_SUFFIX=64", "", d)}     ${@base_conditional("libdir", "/usr/lib32", "-DLIB_SUFFIX=32", "", d)}   -DWITH_OPENCLAMDBLAS=OFF -DWITH_OPENCLAMDFFT=OFF -DBUILD_opencv_dnn=OFF -DWITH_EIGEN=ON -DWITH_GPHOTO2=ON -DWITH_GSTREAMER=ON -DWITH_GTK=ON -DWITH_JASPER=OFF -DWITH_JPEG=ON -DWITH_FFMPEG=OFF -DWITH_LIBV4L=ON -DWITH_OPENCL=OFF -DWITH_PNG=ON -DPYTHON3_NUMPY_INCLUDE_DIRS:PATH=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/aarch64-xilinx-linux/opencv/3.1+gitAUTOINC+92387b1ef8-r0/recipe-sysroot/usr/lib/python3.5/site-packages/numpy/core/include -DBUILD_EXAMPLES=ON -DINSTALL_PYTHON_EXAMPLES=ON -DWITH_TBB=ON -DBUILD_opencv_text=OFF -DWITH_TIFF=ON -DWITH_V4L=ON which triggered exception NameError: name 'base_conditional' is not defined
Summary: There were 2 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build project
Then i fix theproblem i copy openCV from .../petalinux/2019.1/components/yocto/source/arm/layers/meta-petalinux/recipes-support to {PROJ ADDR}/projectspec/metauser
and it's work can build until last process it isn't work
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:01:08
Parsing of 2780 .bb files complete (0 cached, 2780 parsed). 3815 targets, 150 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
  /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/project-spec/meta-user/recipes-devtools/protobuf/protobuf_3.4.1.bbappend
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version 3.1+% of opencv not available (for item opencv)
NOTE: versions of opencv available: 3.4.3+gitAUTOINC+b38c50b3d0_1f6d6f0626_bdb7bb85f3_34e4206aef_fccf7cd6a4
NOTE: preferred version 3.1+% of opencv not available (for item libopencv-ml)
NOTE: preferred version 3.1+% of opencv not available (for item libopencv-core)
NOTE: preferred version 3.1+% of opencv not available (for item opencv-dev)
NOTE: preferred version 3.1+% of opencv not available (for item libopencv-objdetect)
NOTE: preferred version 3.1+% of opencv not available (for item libopencv-calib3d)
NOTE: preferred version 3.1+% of opencv not available (for item libopencv-highgui)
NOTE: preferred version 3.1+% of opencv not available (for item libopencv-imgproc)
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:08
Checking sstate mirror object availability: 100% |###########################################################################################################################################| Time: 0:00:35
Sstate summary: Wanted 1983 Found 1356 Missed 1254 Current 0 (68% match, 0% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
Currently  8 running tasks (5512 of 6372)  86% |################################################################################################################WARNING: dnndk-1.0-r0 do_package_qa: QA Issue: dnndk: found library in wrong location: /usr/local/lib/libn2cube.so [libdir]
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Could not invoke dnf. Command '/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/recipe-sysroot-native/usr/bin/dnf -v --rpmverbosity=debug -y -c /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/etc/dnf/dnf.conf --setopt=reposdir=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/etc/yum.repos.d --repofrompath=oe-repo,/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/oe-rootfs-repo --installroot=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs --setopt=logdir=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp --nogpgcheck install packagegroup-petalinux-opencv parted-dbg parted watchdog-init dnndk shadow parted-dev pciutils udev-extraconf canutils hellopm bridge-utils packagegroup-core-ssh-dropbear kernel-modules packagegroup-core-boot dpu packagegroup-petalinux-matchbox mtd-utils run-postinsts autostart packagegroup-petalinux-x11 base-passwd openssh-sftp-server packagegroup-petalinux-v4lutils libmali-xlnx tcf-agent' returned 1:
DNF version: 2.7.5
cachedir: /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/var/cache/dnf
Added oe-repo repo from /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/oe-rootfs-repo
repo: using cache for: oe-repo
not found deltainfo for: oe-repo
not found updateinfo for: oe-repo
oe-repo: using metadata from Thu 25 Jul 2019 06:56:05 AM UTC.
Last metadata expiration check: 0:00:00 ago on Thu 25 Jul 2019 06:56:06 AM UTC.
--> Starting dependency resolution
--> Finished dependency resolution
Error:
 Problem: conflicting requests
  - nothing provides libopencv_core.so.3.1()(64bit) needed by dnndk-1.0-r0.plnx_zynqmp
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp/log.do_rootfs.10749
ERROR: Task (/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6316 tasks of which 4039 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
i'm checking package of petalinux 2019.1 on ubuntu 18.04 ,i'm installed all file
Anyone can fix this problem or how to edit invoke dnf ?
Re: DPU Tutorial 2019.1
Thank for reply me
I found the solution for use petalinux 2019.1 with dpu setting from your hdf file
You must download zcu102 version 2019.1 in dpu trd topic from this <link>
After you extract file to your location
1. cd to you place project
2. create your project by BSP  file petalinux-create -t project -s...[Location you extract file]/zcu102-dpu-trd-2019-1-timer/apu/dpu_petalinux_bsp/xilinx-dpu-trd-zcu102-v2019.1.bsp
3. cd [to your BSPproject]/project-spec/meta-user
4.follow from this step
cp -r recipes-apps/dnndk/ [Your petalinux-project-v2019.1 path ]/project-spec/meta-user/recipes-apps/
cp -r recipes-modules [Your petalinux-project-v2019.1 path ]/project-spec/meta-user
cp -r recipes-apps/autostart [Your petalinux-project-v2019.1 path ]/project-spec/meta-user/recipes-apps/
cp -r recipes-core/base-files/ [Your petalinux-project-v2019.1 path ]/project-spec/meta-user/recipes-core/
After that Follow from DPU-Integration Generating the Linux Platform in PetaLinux...step 3
Observer stephen_lim
Re: Petalinux-build error Can't not invoke dnf
Why don't you refer to the below link?
http://lists.openembedded.org/pipermail/openembedded-devel/2018-January/116590.html
As for the contents, I think you need to try to  use @bb.utils.contains instead of @base_conditional.
-                ${@base_conditional('SITEINFO_ENDIANNESS', 'le', '--with-endianness=little', '--with-endianness=big', d)} \
+                ${@bb.utils.contains('SITEINFO_ENDIANNESS', 'le', '--with-endianness=little', '--with-endianness=big', d)}
Good luck~
I followed DPU Integration Tutoial on ZCU102 with Vivado & Petalinux v2018.2 and seeing the same issue.
Chris
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Could not invoke dnf. Command '/home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/recipe-sysroot-native/usr/bin/dnf -y -c /home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/etc/dnf/dnf.conf --setopt=reposdir=/home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/etc/yum.repos.d --repofrompath=oe-repo,/home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/oe-rootfs-repo --installroot=/home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs --setopt=logdir=/home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp --nogpgcheck install hellopm openssh-sftp-server tcf-agent packagegroup-petalinux-opencv dnndk bridge-utils packagegroup-petalinux-x11 run-postinsts packagegroup-core-boot mtd-utils libmali8 kernel-modules dpu udev-extraconf pciutils canutils shadow autostart packagegroup-core-ssh-dropbear packagegroup-petalinux-matchbox packagegroup-petalinux-v4lutils base-passwd' returned 1:
Added oe-repo repo from /home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/oe-rootfs-repo
Last metadata expiration check: 0:00:01 ago on Thu 01 Aug 2019 09:21:22 PM UTC.
Error:
Hello Chris!
Did you add the opencv 3.1 recipe in recipes-support? In order to use DPU v1.3.0, you should use opencv 3.1 instead of 3.3 in petalinux 2018.2.
1. Add the opencv 3.1 recipe
cp -rp ../files/recipes-support project-spec/meta-user
2. Append the below into petalinuxbsp.conf
PREFERRED_VERSION_opencv ?= "3.1+%"
OPENCV_PACKAGES_remove = " \
libopencv-ccalib \
I hope that you would be good.
Stephen
Hello Stephen
the document updated Link , it's doesn't use openCV 3.1
I try to build project on Petalinux2019.1 again later I'm update chaged
Parsing recipes: 100% |##########################################| Time: 0:01:06
Initialising tasks: 100% |#######################################| Time: 0:00:08
Checking sstate mirror object availability: 100% |###############| Time: 0:00:35
Sstate summary: Wanted 1977 Found 1356 Missed 1242 Current 0 (68% match, 0% complete)
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Could not invoke dnf. Command '/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/recipe-sysroot-native/usr/bin/dnf -v --rpmverbosity=debug -y -c /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/etc/dnf/dnf.conf --setopt=reposdir=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/etc/yum.repos.d --repofrompath=oe-repo,/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/oe-rootfs-repo --installroot=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs --setopt=logdir=/home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp --nogpgcheck install watchdog-init shadow canutils kernel-modules packagegroup-core-ssh-dropbear base-passwd packagegroup-core-boot run-postinsts pciutils packagegroup-petalinux-opencv openssh-sftp-server packagegroup-petalinux-v4lutils autostart packagegroup-petalinux-x11 dpu bridge-utils packagegroup-petalinux-matchbox udev-extraconf hellopm tcf-agent dnndk mtd-utils libmali-xlnx' returned 1:
DNF version: 2.7.5
oe-repo: using metadata from Thu 01 Aug 2019 08:06:58 AM UTC.
Last metadata expiration check: 0:00:00 ago on Thu 01 Aug 2019 08:06:58 AM UTC.
Error:
  - nothing provides libopencv_core.so.3.3()(64bit) needed by dnndk-1.0-r0.plnx_zynqmp
ERROR: Logfile of failure stored in: /home/ohm/vam_bael/petalinux_2019_1/petalinux_dpu_ultra96/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp/log.do_rootfs.27955
NOTE: Tasks Summary: Attempted 6297 tasks of which 4040 didn't need to be rerun and 1 failed.
Summary: There was 1 WARNING message shown.
I think it's want openCV3.3 but I'm not have recipes
If you use DPU v2.0(arch v1.4.0), opencv 3.3 is required by DNNDK.
I'm attaching a oencv 3.3 recipe in recipe-support.
And, you should add the below into petalinuxbsp.conf in order to use open 3.3 instead of 3.4 because petalinux 2019.1 uses opencv 3.4 basically.
in petalinuxbsp.conf
PREFERRED_VERSION_opencv ?= "3.3+%"
I think you need to modify the opencv 3.3 recipe for Petalinux 2019.1.
Good luck~
Thanks Stephen! I got passed the opencv 3.1 errors but now I have protobuf and protobuf-native errors. Any suggestion?
Chris.
WARNING: protobuf-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Failed to fetch URL git://github.com/google/protobuf.git;branch=3.4.x, attempting MIRRORS if available
ERROR: protobuf-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Fetcher failure: Unable to find revision b04e5cba356212e4e8c66c61bbe0c3a20537c5b9 in branch 3.4.x even from upstream
ERROR: protobuf-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Fetcher failure for URL: 'git://github.com/google/protobuf.git;branch=3.4.x'. Unable to fetch URL from any source.
ERROR: protobuf-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/aarch64-xilinx-linux/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/temp/log.do_fetch.19316
ERROR: Task (/home/chris/Tools/Petalinux/2018.2/components/yocto/source/aarch64/layers/meta-openembedded/meta-oe/recipes-devtools/protobuf/protobuf_3.4.1.bb:do_fetch) failed with exit code '1'
WARNING: protobuf-native-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Failed to fetch URL git://github.com/google/protobuf.git;branch=3.4.x, attempting MIRRORS if available
ERROR: protobuf-native-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Fetcher failure: Unable to find revision b04e5cba356212e4e8c66c61bbe0c3a20537c5b9 in branch 3.4.x even from upstream
ERROR: protobuf-native-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Fetcher failure for URL: 'git://github.com/google/protobuf.git;branch=3.4.x'. Unable to fetch URL from any source.
ERROR: protobuf-native-3.4.1+gitAUTOINC+b04e5cba35-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/chris/FPGA/l2_zcu102/l2_zcu102.peta/build/tmp/work/x86_64-linux/protobuf-native/3.4.1+gitAUTOINC+b04e5cba35-r0/temp/log.do_fetch.19351
ERROR: Task (virtual:native:/home/chris/Tools/Petalinux/2018.2/components/yocto/source/aarch64/layers/meta-openembedded/meta-oe/recipes-devtools/protobuf/protobuf_3.4.1.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6546 tasks of which 6511 didn't need to be rerun and 2 failed.
Thank you stephen_lim &  chrischan  for your guidance
Now DPU Integration update It's not has protobuf problem
I try to down version opencv in petalinux 2019.1 from 3.4.2 to 3.3 (I'm copy openCV 3.3 from petalinux 2018.2 /opt/pkg/petalinux/2018.2/components/yocto/source/aarch64/layers/meta-petalinux/recipes-support/opencv to same directory but different version)
Don't forget chaged base condition when you down version from stephen_lim comment http://lists.openembedded.org/pipermail/openembedded-devel/2018-January/116590.html
I think it's work ,While build version opencv changed
But it's call libraries from opencv 3.4.2 ,I'm confussing (version opencv while build chaged)
ERROR log
I prove to check recipe when i selected ,it's will error
It's dnndk from DPU-Itegration .Inside that libraries opencv version 3.3
then , I think i'm waiting dnndk version update on DPU Integration
ERROR log
Participant lucc1
Experiencing all similar problems on my side,
Just want to check,
Did the DPU integration tutorial mentioned has been validated on 2019.1,
I had it working before on 2018.3
Anyone have build a petalinux 2019.1 with the DPU and made it work on a xilinx board?
Does the tutorial needs some update specific for 2019.1?
side note: working with  DNNDK3.1, DPU3.0, vivado 2019.1
Luc Chouinard
FPGA Architect & AI Specialist
Teledyne Imaging
Teledyne Lumenera
Participant lucc1
Quick Reply to:
ohmmaxma007
‎08-01-2019 07:28 PM - edited ‎08-01-2019 07:29 PM
I think it still uses openCV3.1, and there might be good reasons for that as we try other version but had problems, ...  cannot elaborate more on this.
Following the link mentionned by ohmmaxma007 above and going down the hierchy you would find:
https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/DPU-Integration/reference-files/files/recipes-support/opencv
and see that opencv_3.1.bb is there.
Luc Chouinard
Teledyne Imaging
Teledyne Lumenera
Thank for reply me
