Debugging Linux Kernel using xilinx xmd
I am trying to debug linux kernel using xilinx XMD, for that first i am loading u-boot and vmlinux using XMD using dow command and i tried to set a breakpoint using bps command of xmd. But when i tried to run breakpoint is not hitting. Please help me how to debug Linux using Xilinx XMD
Re: Debugging Linux Kernel using xilinx xmd
The vmlinux is an elf with virtual addresses rather than physical, you should be able see those addresses using objdump and this is a good practice to better understand the details. It can be used for debug symbols with a debugger, but not loaded into memory using XMD. The Image and zImage files are binary rather than elf and are created from the vmlinux image during the kernel build.
To my knowledge XMD does not use symbols (I never done it) as that's the job of a debugger that runs on top of XMD like GDB.
You can let u-boot load the normal linux image and then after Linux starts you can stop it in XMD and do stepping and debug. If you need to debug the kernel startup then you need to set a hardware breakpoint at the start address so that XMD will stop after u-boot starts the kernel.
John
Thank you Very much John. I will try this way.
Also I tried another way, in which I tried to detect the processors of zc702 through SDK's run->debug configurations options, but unluckily processors are not getting detected, it is invoking some hw_server and thats all. I am not getting any Idea how to proceed from here on. I followed the below link to debug kernel through TCF:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/SDK_Doc/tasks/sdk_t_tcf_attach_debug_linux_kernel_tcf.htm
I would like to debug the kernel, linux-xilinx through xmd or xilinx SDK , can you please provide me clear steps,
My understnding of the above discussion is " dow uboot to xmd" , "dow uImage to xmd", later start debugging using break points .
lets say
xmd# bps drivers/tty/serial/xilinx_uartps.c :1226
xmd#continue
xmd#n
is that right?
if not please provide me, exact steps for debugging linux kernel.
Thanks in advance
Satish.G
G Satish Kumar
Hi all,
I got partial answer and waiting for ur support.
I got to know how to debug Linux kernel using XMD
boot zed board through SD card and stop booting the board at zed-uboot>
connect xmd debugger through uart and
xmd#connect arm hw
xmd#dow vmlinux
xmd#bps start_kernel hw
xmd#con
 <hitting breakpoint 0 at 0x12345  address>
xmd#stp
xmd#stp
stp is working here, but if we want to see the source code, what will be next step?
if we are not able to see the code through xmd , how it will connect to GDB debugger
thanks in advance
regards
Satsih.G
G Satish Kumar
Hi all,
Can you guys, plerase reply to my post.
I am waiting for positive answer
Thanks & Regards
Satish.G
G Satish Kumar
Hi, I come up with very basic question. The discussion shows that Xilinx XMD is a Linux Kernel which can be used for debugging purpose. Does it means that we can run all Linux commands in Xilinx XMD ?
The board need to be connected all the time with Vivado. How about running full embedded Linux on Zynq  with keyboard and mouse ?
Hi @gsatish10
You can use the AR#67767 as a reference point. When debugging kernel from xsdk (or xsct) you need to enable kernel awareness and load the symbols.
Hi @expertengr
You misunderstood the topic of the post. The discussed feature is about running the linux kernel in the target machine and be able to debug the kernel as it was an standalone application within the Xilinx tools.
Ibai
Is it possible to run embedded linux on Zynq with keyboard and mouse ?
Take a look: http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+-+Installing+the+Ubuntu+Desktop+on+PetaLinux+and+Demo+Tech+Tip
Ibai
so this support debugging of Peta-linux
If we want to test linux-xilinx
support is provided for linux-xilinx ?
Satish,G
G Satish Kumar
