boshkey
Debugging Through TCF agent on Linux kerner built from source code
Dear fellows:
Recently, I'm trying to debug a linux based application through tcf agent, but errors keep occuring.
Since, the filesystem from wiki pages does not have TCF agent. I download the TCF source code from Eclipse, the version is 1.2.
TCF agent executable files is as follows:
zynq> ls
agent libtcf.a system tcf.tar tcfreg
client machine tcf tcflog valueadd
The "agent" can be executed on board, with the command:
zynq> ./agent -s 192.168.1.10:1534 -SRunning TCF agent on target boardRunning TCF agent on target board
But, as I follow the debug procedure UG1144 Section "Performing a Debug Session". Following message occurs at Xilinx SDK Software Debug Page, The photo is in the attachment:
linux_debug_config (target: Disconnected): No space left on device
Error message on Xilinx SDK when trying to connect to targetError message on Xilinx SDK when trying to connect to target
        Can any body give me a hint? Any info could be helpful.
shabbirk
Hi @boshkey
Can you please follow this user guide to debug linux user applications with TCF
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1144-petalinux-tools-reference-guide.pdf
(Debugging Applications with TCF Agent)
Also, make sure that you have the sufficient disk space in your working directory, as the error in 2nd screenshot clearly shows lack of space
Best Regards
Shabbir
boshkey
Thank you for your reply, but the guide only describe the procedure based on petalinux.
I am wondering if it is possible to debug with TCF agent without the help of petalinux, as petalinux is not easy to download and not quite easy to use.
