mariano_severi
Develop Linux app with Xilinx XSDK and Petalinux 2018.2 rootfs
I tried to develop Linux app with Xilinx SDK and Petalinux rootfs following instructions here : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842346/Linux+Applications+with+Petalinux+Libraries
I'm using 2018.2.
Unfortunately I get errors for missing libraries (libc.so.6, for example) but I checked the sysroot folder and libraries are there.
I read in the forum that this may be related to different toolchain, not sure if this is my case as well. I tried to set the petalinux toolchain in XSDK when creating the app (hello world from template) but nothing changed
Any suggestion?
  Mariano
mariano_severi
it seems that the problem is with the libraries path that XSDK automatically adds, that is:
<project_dir>/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/lib
<project_dir>/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/usr/lib
It should be:
By changing the settings. it works, the linker finds the requested libraries and compilation successfully ends.
Mariano
shabbirk
Hi @mariano_severi
May I know the exact error that you are seeing?
Also, see if this forum post helps you
https://forums.xilinx.com/t5/Embedded-Linux/PetaLinux-2017-4-Cross-Compiler-requires-libc-so-6-GLIBC-2-4/td-p/844282
Best Regards
Shabbir
sandeepg
Hi @mariano_severi,
I assume you are experiencing this issue. Refer this AR https://www.xilinx.com/support/answers/69159.html
Note: Do not use Windows XSDK for developing linux app using Petalinux sysroot instead use Linux XSDK.
Sandeep
mariano_severi
here it is the XSDK console log when building the app :
"make all
Building target: helloworld_petalinux.elf
Invoking: ARM v7 Linux gcc linker
arm-linux-gnueabihf-gcc -L"/home/mariano/Work/Xilinx/boards/zedboard/project_01/petalinux/test_01/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/lib" -L"/home/mariano/Work/Xilinx/boards/zedboard/project_01/petalinux/test_01/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi/usr/lib" -Xlinker --sysroot=/home/mariano/Work/Xilinx/boards/zedboard/project_01/petalinux/test_01/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi -o "helloworld_petalinux.elf"  ./src/helloworld.o
/opt/pkg/petalinux-v2018.2/tools/linux-i386/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find /lib/libc.so.6
makefile:36: recipe for target 'helloworld_petalinux.elf' failed
/opt/pkg/petalinux-v2018.2/tools/linux-i386/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find /usr/lib/libc_nonshared.a
/opt/pkg/petalinux-v2018.2/tools/linux-i386/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find /lib/ld-linux-armhf.so.3
collect2: error: ld returned 1 exit status
make: *** [helloworld_petalinux.elf] Error 1"
I'm using Linux XSDK  (running in virtual machine).
There's no uppercase letter in application name.
I added the following to the Linker miscellaneous settings: --sysroot=/home/mariano/Work/Xilinx/boards/zedboard/project_01/petalinux/test_01/images/linux/sdk/sysroots/cortexa9hf-neon-xilinx-linux-gnueabi
I tried using both the petalinux and Xilinx toolchain, but I get the same error.
Any idea? Thanks
  Mariano
sandeepg
Hi @mariano_severi,
Did you tried the AR solution?
Sandeep
stephenm
mariano_severi
sorry but I'm really confused.
If I run (and this is what I was doing so far):
- petalinux-build --sdk
- petalinux-package --sysroot
the tool create the directory images/linux/sdk/cortexa9hf-neon-xilinx-linux-gnueabi
If I use it as sysroot, I get errors for libraries missing.
Instead if I run :
- petalinux-build -c rootfs
the tool create the directories:
-/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/recipe-sysroot-native -/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/rootfs
Now :
- if I use the former as sysroot, I can compile (and run on the target) simple hello world program. However if I try to add xml2 library as suggested in https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842346/Linux+Applications+with+Petalinux+Libraries . I get the following error : lib/libxml2.so: file not recognized: File format not recognized.
- if I use the latter (rootfs) as sysroot, I still can compile the hello world program but, when adding xml2 library, I get the error  cannot find -lxml2. Indeed, I find that rootfs/usr/lib contains libxml2.s0.2 and not libxml2.so and rootfs/user/include is completely empty
What shall I do?
  Mariano
mariano_severi
It should be:
Mariano
jannik.mahr
Thank you! Had the same issue and this did the trick.
Petalinux really should have a better integration of the XSDK. There should be some kind of Petalinux command that lets you create a Petalinux app which automatically sets up a XSDK workspace and project.
jannik.mahr
I have to revert my previous answer, the trick did work but caused other problems.
The real solution was following this AR: https://www.xilinx.com/support/answers/69159.html which @sandeepg posted.
mariano_severi
in my case, the directory indicated in the suggested AR is not populated. Is that applicable also for 2018.2?
Btw, I did add the --sysroot linker flag as well, sorry  I didn't mention it
  Mariano
