11-09-2016 04:57 AM - edited 11-09-2016 05:02 AM
I'm trying to find info on the required and optional bindings of for the GMII2RGMII IP block, which I'm using on my Zynq GEM1 interface.
I'm looking under linux-xlnx/Documentation/devicetree/bindings, but no success.
on this link I've found some example, but it seems old, the compatible = "xlnx,gmii2rgmii" string seems to be deprecated (?)
ps7_ethernet_1: ps7-ethernet@e000c00 { #address-cells = <1>; #size-cells = <0>; compatible = "xlnx,ps7-ethernet-1.00.a"; gmii2rgmii-phy-handle = <&phy1>; interrupt-parent = <&ps7_scugic_0>; interrupts = < 0 45 1 >; local-mac-address = [ 00 0a 35 00 00 00 ]; phy-handle = <&phy0>; phy-mode = "gmii"; reg = < 0xe000c000 0x1000 >; xlnx,enet-clk-freq-hz = <0x7735940>; xlnx,enet-reset = <0xffffffff>; xlnx,enet-slcr-1000mbps-div0 = <0x1>; xlnx,enet-slcr-1000mbps-div1 = <0x1>; xlnx,enet-slcr-100mbps-div0 = <0x1>; xlnx,enet-slcr-100mbps-div1 = <0x5>; xlnx,enet-slcr-10mbps-div0 = <0x1>; xlnx,enet-slcr-10mbps-div1 = <0x32>; xlnx,eth-mode = <0x0>; xlnx,has-mdio = <0x1>; xlnx,ptp-enet-clock = <111111115>; mdio { #address-cells = <1>; #size-cells = <0>; phy0: phy@7 { compatible = "marvell,88e1116r"; device_type = "ethernet-phy"; reg = <7>; } ; phy1: phy@8 { compatible = "xlnx,gmii2rgmii"; device_type = "ethernet-phy"; reg = <8>; } ; } ; } ;
11-09-2016 07:10 AM
Yes, the compatible string "xlnx,gmii2rgmii" doesn't exist in kernel 4.4. Looks like "xlnx,ps7-ethernet-1.00.a" should work. All the gmii2rgmii_phy functionality is in xlinix_emacps.c now.
11-13-2017 11:59 PM - edited 11-14-2017 12:00 AM
@rgrossman, coming back to this post ... I'm still having trouble getting my eth1 with GMII2RGMII convertor to work, see this new thread that I started.
I'm currently using Petalinux 2017.2, which uses kernel 4.9
Do you happen to have a device tree example for such eth + gmii2rgmii node? If so would you mind sharing it?
