Device tree error while building with ADI bitfile
We have encountered the error
ERROR: device-tree-xilinx+gitAUTOINC+b7466bbeee-r0 do_compile: Function failed: do_compile (log file is located at /home/gtestbed/radio_sat/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.8673)
ERROR: Logfile of failure stored in: /home/gtestbed/radio_sat/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.8673
while following the below steps:
Step-1: We generated bitstream of the example ADRV9009 ZCu102 workspace successfully
Step-2: Created Petalinux project along with with HDF file and generated device-tree & other outputs successfully
Step-3: We tried doing petalinux build using the above outputs, which is generating error as attached.
Petalinux Version Used: 2018.3
Vivado Version used: 2018.3
Board Configured for: ZCU102 v1.1
Can you please guide us resolve this error..
Re: Device tree error while building with ADI bitfile
Hi @manibenwa
It would help if you could share the log file generated:
Florent
If you share the HDF then we can debug this error, and possibly provide a fix. Otherwise the log that contains the error message so we can aid in debugging the issue
Ok, great. Can you make your post as slution then please. This will help others
