Visitor turcant
Device tree overlay on ZCU102 : why isn't there an amba_pl in pl.dtsi ?
Hi all,
I'm working on ZCU102 with Yocto.
My objective is to change the bitstream while Linux is running using fpgautil.
Using this webpage: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841847/Solution+ZynqMP+PL+Programming, I'm able to change the bitstream correctly.
However, my device-tree overlay isn't working correctly, I can't load my driver (which is working fine without playing with the overlays).
Here is my device-tree overlay:
/dts-v1/;
/plugin/;
  fragment@0 {
    target = <&fpga_full>;
    overlay0: __overlay__ {
      #address-cells = <2>;
      #size-cells = <2>;
      firmware-name = "my_design.bit";
      resets = <&rst 116>;
  fragment@3 {
    target = <&amba>;
    __overlay__ {
      #size-cells = <2>;
      my_ip: my_ip@4F8000000 {
        compatible = "company,my_ip";
        device-name = "my_ip";
        reg = <0x00000004 0xF8000000 0x0 0x20000
                   0x00000004 0xF8020000 0x0 0x20000
                   0x00000004 0xF8800000 0x0 0xFFF
                   0x00000004 0xF8900000 0x0 0xFFF
                   0x00000004 0xF8920000 0x0 0xFFF>;
        interrupt-parent = <&gic>;
        interrupts = < 0 89 1 >,
                           < 0 90 1 >,
                           < 0 91 1 >,
                           < 0 104 1 >,
                           < 0 105 1 >,
                           < 0 106 1 >,
                           < 0 110 4 >,
                           < 0 111 4 >;
To what does the number after fragment@ correspond ?
In my pl.dtsi automatically generated by Xilinx tools for Yocto, I don't see any "amba_pl" part, just an "amba".
In my DTO, when I choose the target amba_pl, the dtbo can't be loaded:
[ 228.825804] OF: resolver: overlay phandle fixup failed: -22
[ 228.831391] create_overlay: Failed to resolve tree
DTBO loading through zynqMP FPGA manager failed
When I choose the target "amba", the DTO load correctly, however the driver isn't able to make write/read operation and then the linux hang. I read that amba is the target for peripherals connected to the ARM processor, so the correct target would be "amba_pl", meant for peripherals on the fpga ?
Can some enlighten me on the subject ?
You can find attached my pl.dtsi generated by Yocto
Nicolas
