Observer tkato@poc.com
Device tree overlay phandle error
We have a system with 4 GEMs with a shared MDIO connected to GEM2. Since the drivers probe based on acesending memory (), the first two gems GEM0 and GEM1 are probed prior to having a phy handle and therefore never made available upon entering the kernel.
To fix this we are trying to apply a device tree overlay in which enables 3 GEMs so that only GEM2 is initially probed. Here is the .dtsi:
/dts-v1/;
/plugin/;	/* allow undefined label references and record them */
	fragment@0 {
		target = <&gem0>;
		__overlay__ {
            		status = "okay";
	fragment@1 {
		target = <&gem1>;
		__overlay__ {
            		status = "okay";
	fragment@2 {
		target = <&gem3>;
		__overlay__ {
            		status = "okay";
After following the commands presented in the wiki: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841645/Solution+Zynq+PL+Programming+With+FPGA+Manager
The following error are encountered:
# cd /configfs/device-tree/overlays/
# ls
# mkdir full
# echo -n "gem.dtbo" > full/path
[  309.784166] OF: resolver: no symbols in root of device tree.
[  309.789828] OF: resolver: overlay phandle fixup failed: -22
[  309.795393] create_overlay: Failed to create overlay (err=-22)
I'm unsure why the phandles are having issues with the device tree. Has anyone been able to resolve this?
Observer kawazome
Re: Device tree overlay phandle error
It seems that symbol information is not included in the root device tree.
When building the root device tree, add  -@  or --symbol to the dtc command.
For details, see “Compiling a Device Tree Overlay Blob (.dtbo) file from the pl.dts file.” at the following URL.
I have seen this before, but only for nodes in the pl.dtsi. Can you post your system-user.dtsi please?
Sure here it is:
 * CAUTION: This file is automatically generated by Xilinx.
 * Version: XSCT 2019.1
 * Today is: Wed Oct 30 22:54:19 2019
/dts-v1/;
#include <dt-bindings/../../../../../board/zynqmp/dts/zynqmp.dtsi>
#include <dt-bindings/../../../../../board/zynqmp/dts/zynqmp-clk-ccf.dtsi>
#include <dt-bindings/../../../../../board/zynqmp/dts/pl.dtsi>
#include <dt-bindings/../../../../../board/zynqmp/dts/pcw.dtsi>
#include <dt-bindings/input/input.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pinctrl/pinctrl-zynqmp.h>
#include <dt-bindings/phy/phy.h>
	chosen {
		bootargs = "earlycon clk_ignore_unused";
		stdout-path = "serial0:115200n8";
	aliases {
		ethernet0 = &gem0;
		ethernet1 = &gem1;
		ethernet2 = &gem2;
		ethernet3 = &gem3;
		i2c0 = &i2c0;
		i2c1 = &i2c1;
		serial0 = &uart0;
		serial1 = &uart1;
		spi0 = &qspi;
		spi1 = &spi0;
		spi2 = &spi1;
	memory {
		device_type = "memory";
		reg = <0x0 0x0 0x0 0x7ff00000>;
    /* supply voltage to audio codecs - grabbed from old DTS*/
	vcc_1v8: regulator-fixed-1v8 {
		compatible = "regulator-fixed";
		regulator-name = "VCC_1V8";
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <1800000>;
	vcc_3v3: regulaor-fixed-3v3 {
		regulator-name = "VCC_3V3";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		regulator-initial-mode = <0x0e>; /* RES_STATE_ACTIVE */
		regulator-always-on; /* due vcc_1v8 leak to AIC34 VDDs */
&gem3 {
	status = "disabled";
	phy-handle = <&phy1>;
	phy-mode = "rgmii";
	local-mac-address = [00 0a 35 00 00 03];
&gem2 {
	status = "okay";
	phy-handle = <&phy0>;
	phy-mode = "rgmii";
	local-mac-address = [00 0a 35 00 00 02];
	phy0: phy@0 {
		reg = <0x0>;
		ti,rx-internal-delay = <0x8>;
		ti,tx-internal-delay = <0xa>;
		ti,fifo-depth = <0x1>;
		ti,rxctrl-strap-worka;
	phy1: phy@1 {
		reg = <0x1>;
	phy8: phy@8 {
		reg = <0x8>;
        xlnx,phy-type = <0x4>;
	phy2: phy@2 {
		reg = <0x2>;
&gem1 {
	phy-handle = <&phy8>;
	phy-mode = "sgmii";
	reset-gpios = <&gpio 45 0>;
	local-mac-address = [00 0a 35 00 00 01];
&gem0 {
	phy-handle = <&phy2>;
	phy-mode = "sgmii";
	reset-gpios = <&gpio 13 0>;
	local-mac-address = [00 0a 35 00 00 00];
&i2c1 {
	status = "okay";
	clock-frequency = <400000>;
	scl-gpios = <&gpio 16 GPIO_ACTIVE_HIGH>;
	sda-gpios = <&gpio 17 GPIO_ACTIVE_HIGH>;
	acodec: tlv320aic34@18 {
		compatible = "ti,tlv320aic3x";
		reg = <0x18>;
		gpio-reset = <&gpio 38 GPIO_ACTIVE_HIGH>;
		AVDD-supply = <&vcc_3v3>;
		DRVDD-supply = <&vcc_3v3>;
		IOVDD-supply = <&vcc_1v8>;
		DVDD-supply = <&vcc_1v8>;
	bcodec: tlv320aic34@19 {
		reg = <0x19>;
&spi0 {
	status = "okay";
	num-cs = <3>;
	is-decoded-cs = <0>;
	label = "Audio-SPI";
	spi0_0: spi5a@0 {
		compatible = "linux,spidev";
		reg = <0>;
		spi-max-frequency = <4000000>;
	spi0_1: spi5a@1 {
		reg = <1>;
	spi0_2: spi5a@2 {
		reg = <2>;
Observer kawazome
Adding -@ seemed to do the trick but now the drivers don't actually seem to enable the additional GEMs. Are there further steps needed when attempting to enable a GEM once inside linux?
Observer kawazome
Device-tree-overlay can add and remove nodes, but unless you have a special case, changes in the properties in the node will not be reflected.
After booting Linux with the gem0, gem1, and gem3 nodes removed from the root device-tree, try adding the gem0, gem1, and gem3 nodes with the device-tree overlay.
After fixing the overlay errors and adding in some TI phy attributes we were able to properly link the MACB drivers with the PHYs.
I'll also give your suggested method a try as well.
Thanks!
