Device tree system-user.dtsi, not building
I am trying to allocate some reserved memory in petalinux as in the wiki/confluence page;
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841683/Linux+Reserved+Memory
I have a project based on the ZCU111 (RFSoC eval), i have added a modified 'system-user.dtsi' as shown in the wiki/confluence page this appears to compile and i can boot the image,  however this image when booted does not show reservered memory using command;
'cat /proc/iomem.'
Injecting syntax errors in the system.dtsi does not cause errors when i run "petalinux-build -c device-tree" , however "petalinux-build -b device-tree" does causes errors (as expected due to the syntax errrors)., but i'm unsure how to build this 'system.dtb' into the 'image.ub'
The project doesn't appear to always be including system-user.dtsi?
Any pointers on what is going wrong or what to try.
Tim
Re: Device tree system-user.dtsi, not building
Also, you can always quickly compile the DT if you are making changes here as running through the tools can be time consuming:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/136904764/Creating+Devicetree+from+Devicetree+Generator+for+Zynq+Ultrascale+and+Zynq+7000
cd <plnx proj>/components/plnx_workspace/device-tree/device-tree
gcc -I ../../../../project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi -E -nostdinc -undef -D__DTS__ -x assembler-with-cpp -o my_dts/system-top.dts.tmp system-top.dts
dtc -I dts -O dtb -o system-top.dtb system-top.dts.tmp
Once you are happy, then as Sandeep says:
  • petalinux-build -c device-tree -x cleanstate
It appears the running "petalinux-build -c device-tree" build on first build and includes "system-user.dtsi" file.
Subsequent rebuild using "petalinux-build -c device-tree" does not rebuild even if changes to the "system-user.dtsi" file have been applied.
I am forced to do a "petalinux-build -x mrproper" to clean the project, then rebuild using "petalinux-build".
Is this expected behaviour of the petalinux tools?
Tim
Hi @tmonaghan84 ,
Whenever you add nodes to system-user.dtsi you need to run cleansstate.
$ petalinux-build -c device-tree -x cleansstate
With this it should generate the right nodes and you no need to run "petalinux-build -x mrproper"
Once you run any bitbake recipe for example in this case it's "device-tree" you can verify the list of task executed in log.task_order file
$ cat <TMPDIR>/<PROJECT_NAME>/work/<YOCTO_MACHINE_NAME>-xilinx-linux/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/log.task_order
Sandeep
should be
