Does arm trusted firmware required to boot linux on zynqmp zcu102 devkit ?
I am using zynqmp zcu_102 dev kit and trying to replace fsbl with spl. I am able to generate spl/boot.bin and u-boot.img with help of (http://www.wiki.xilinx.com/U-Boot+Secondary+Program+Loader)  and uboot load & boot without issue with generated files(MMC BOOTMODE) but uboot not able to load kernel image(Image). Is it something related to arm-trusted firmware image? If yes then how can i embedded with spl/boot.bin or any alternate way.
Should i need to use bootgen command or mkimage?
Re: Does arm trusted firmware required to boot linux on zynqmp zcu102 devkit ?
Hi Paresh
Looks like this issue is nothing to do with arm-trusted-firmware.
You can try creating uImage with mkimage utility and make sure you have proper *.dtb file.
Best Regards
Shabbir
