suppamax
Driving AXI-SPI from linux
in my design the ARM core can configure the blocks implemented in PL via a AXI2SPI  module.
I configured the linux with the following options
CONFIG_SPI_XILINX=y
CONFIG_SPI_SPIDEV=y
and my device-tree looks like
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		axi_quad_spi_0: axi_quad_spi@a0000000 {
			bits-per-word = <8>;
			compatible = "xlnx,xps-spi-2.00.a";
			fifo-size = <16>;
			interrupt-names = "ip2intc_irpt";
			interrupt-parent = <&gic>;
			interrupts = <0 89 1>;
			num-cs = <0x1>;
			reg = <0x0 0xa0000000 0x0 0x800000>;
			xlnx,num-ss-bits = <0x1>;
			xlnx,spi-mode = <0>;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			/* This is a place holder node for a custom IP, user may need to update the entries */
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
Now - it's not clear to me how it is possible to control the AXI2SPI module.
I understand I should use the spi-xilinx driver, but I don't know how to do it (nor how to check that it has been correctly loaded).
gudishak
Hi @suppamax,
you can try test procedure mentioned in below wiki,
http://www.wiki.xilinx.com/Linux%20SPI%20Driver
Kranthi
Best Regards
Kranthi
suppamax
Do you mean that I should add a "my_component" node within axi_quad_spi, which will allow me to access my PL logic?
suppamax
Also, here is the boot log: there is no message regarding spi.
Is this expected?
How to debug this issue?
