dpekin
Dropbear build for zc702 error
I am in the process of rebuilding the ramdisk for the zc702 dev board.
Following the wiki, I believe busybox is coross compiled correctly.  Then, when I run
make PROGRAMS="dropbear dbclient dropbearkey dropbearconvert scp" MULTI=1 strip
The make fails when trying to run "strip dropbearmulti"  The error is
"strip: Unable to recognise format of the input file 'dropbearmulti'"
I am cross compiling on Ubuntu 12.04.  This works fine for building the kernel.
Any thoughts or work arounds?
- Dave
linnj
I think the kernel expects the dev directory to exist on the root file system and if not you may get that error.
linnj
Hi Dave,
I don't have any great answers, could be something is different with 12.04. That's the joy of cross compiling, but in this case it sounds like it might have built, but just be stripped so the binary is bigger than expected. Maybe the command line has to be different.
We have moved to just using open ssh rather than dropbear. Since we needed secure FTP we had to have that from open ssh anyway. We have not released that ramdisk image yet as it's going to be for 14.3.
dpekin
Thanks.  I removed the "strip" from the command line and the make script for dropbear finishes.
I continued to create the ramdisk.  After the kernel loads and it tries to mount the ramdisk I receive a "devtmpfs: error mounting -2"  message. Then the system crashes.
Anyone have any ideas?
I will try to mount the FS on QEMU to see if it works there.
- Dave
linnj
dpekin
Thanks.  My mistake.  I failed to have the correct directory structure.
The default ramdisk is 8M.   Do you know offhand the max size for the zc702 dev board?
- Dave
linnj
16 MB I believe the way the kernel is configured.
