thenumberdevil
Dumbing the entire physical memory in xilinx
      I want to dump  the entire RAM to a file which I can use for future analysis. I could use /dev/mem only in the area of RAM not required by any driver. I want to dump the memory in the way similar to /dev/ram but with out any restriction.
stephenm
You could use JTAG using XSCT to do this. It might take a while though
thenumberdevil
Hi ,
       My system currently running baremetal, then uboot, and then linux. If I use JTAG, I can watch the memory all the way through right.
thenumberdevil
Hi @stephenm ,
                         I used this trick mentioned by you and I could see the entire RAM using the JTAG and sdk. Do we have a option to see the system address beyond system RAM memory.
For eg : IP block is in the range of 0x43d00000 which is beyond the ram(In our case the ram size is 512MB ) . If I can see this address in the sdk, It will help me to visually verify if the data is written perfectly in this address.
stephenm
you can use the mrd command to read any valid memory or register address
thenumberdevil
Hi @stephenm ,
                           Thank you for your reply. I tried mrd command. But could not get it right. Could you please let me know what mistake I am doing
xsct% mrd -address-space ap1 0x43ca0000
xsct% unknown or ambiguous address space "ap1": must be PA
mrd -address-space PA 0x43ca0000
xsct% Memory read error at 0x43CA0000. Blocked address 0x43ca0000. PL AXI slave ports access is not allowed. This address has not beed added to the memory map
mrd -address-space AP0 0x43ca0000
xsct% unknown or ambiguous address space "AP0": must be PA
mrd -address-space AP0 0x43d00000
mrd -address-space AP1 0x43d00000
xsct% unknown or ambiguous address space "AP1": must be PA
mrd -force 0x43d00000
In my case at 0x43d00000 I have  IP block, and I would like to check the register contents of the ipblock.
stephenm
You could make a script to do this for you. Input the HDF/XSA file and use the HSI API to read the all the IP in a processors address map. Then get the base address and high address.
proc dump {filter file} {
	set fileId [open $file "w"]
	if {$filter == 0} {
		set mem [hsi::get_cells *]
	} else {
		set mem [hsi::get_cells * -filter $filter]
	for {set j 0} {$j < [llength $mem]} {incr j} {
		puts $fileId "[common::get_property NAME [lindex $mem $j]]"
		puts $fileId  "BASE_VALUE: [common::get_property CONFIG.C_S_AXI_BASEADDR [hsi::get_cells [lindex $mem $j]]]"
		puts $fileId  "HIGH_VALUE: [common::get_property CONFIG.C_S_AXI_HIGHADDR [lindex $mem $j]]"
		set range [get_range [lindex $mem $j] [common::get_property CONFIG.C_S_AXI_HIGHADDR [lindex $mem $j]] [common::get_property CONFIG.C_S_AXI_BASEADDR [lindex $mem $j]]]
		if {$range > 0} {
			if { [catch {[mrd -force [common::get_property CONFIG.C_S_AXI_BASEADDR [hsi::get_cells [lindex $mem $j]]] $range]} fid] } {
			    puts "Warning: $fid"
			} else {
				puts $fileId [mrd -force [common::get_property CONFIG.C_S_AXI_BASEADDR [hsi::get_cells [lindex $mem $j]]] $range]
	close $fileId
	puts "Info: $file created"
This uses the XSCT mrd. It also has a catch so it wont crash on an illegal access
I have attached a TCL script to do this in XSCT:
Just source this, and run the command below:
This will create a dump.log
There is a filter that you can use too, and you should use this otherwise it will dump everything in your system.
dump_mem -filter {IP_TYPE == MEMORY}
