genadyk_kama
EMMC boot problem on UtraZed board
I am using the Avnet Ultrazed board , the board have option to boot from SDACRD or EMMC  flash located on board
I am trying to boot from EMMC flash , the SDCARD is removed
The boot working ok , but  I see the following  messages during the boot:
MMC: sdhci_send_command: MMC: 1 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 3200 ms.
After the messages the boot working fine
When SDCARD is connected , there are no such messages
Is there any solution to  prevent from u-boot  to check the SDCARD connection ?
