ERROR: Failed to source bitbake
HI,
     I am using petalinux 2017.2 on Ubuntu16.04,  petalinux 2017.2 works good in these  days. But when i install vivado 2017.2 on Ubuntu16.04. When i petalinux-config exit, I meet these error.
    ERROR: Failed to source bitbake.
Can you  give me  some suggestions?
Thanks!
Hi @mrzhang_,
Can you post the output of your bashrc file?
Sandeep
Hi @mrzhang_,
Sandeep
@sandeepg
Thank you.
bashrc is correct.
Now, It is ok. But  i don't know what's reasons cause this problem.
Yesterday, I am using internet to download sstate cache, bitbake can't work correctly.  But When I download completely, bitbake work correctly.
