Visitor rrx
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_cpu_cortexa53::generate
We are in process of moving up from 2018.1 to 2018.3 .. the 2018.3 petalinux build fails as output shows below.   Any suggestions ?
| cmd is: xsct -sdx -nodisp /opt/workspace/2018.3/revA/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/dtgen.tcl -ws /opt/workspace/2018.3/revA/build/../components/plnx_workspace/device-tree -pname device-tree -rp /opt/workspace/2018.3/revA/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/git -processor psu_cortexa53_0 -hdf /opt/workspace/2018.3/revA/build/tmp/deploy/images/plnx-zynqmp/Xilinx-plnx-zynqmp.hdf -arch 64 -app "device-tree" -hdf_type hdf -yamlconf /opt/workspace/2018.3/revA/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/device-tree.yaml
| INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds
| hsi::open_hw_design: Time (s): cpu = 00:00:08 ; elapsed = 00:00:12 . Memory (MB): peak = 949.738 ; gain = 308.785 ; free physical = 102 ; free virtual = 3941
| invalid command name "+"
| ERROR: [Hsi 55-1545] Problem running tcl command ::sw_cpu_cortexa53::generate : invalid command name "+"
| while executing
| "+ set node_data [split $node ":"]"
| ("foreach" body line 3)
| invoked from within
| "foreach node ${dts_nodes} {
| if {[regexp $lu_node $node match]} {
| invoked from within
| "foreach dts_file ${dts_files} {
| set dts_nodes [get_all_tree_nodes $dts_file]
| (procedure "get_node_object" line 9)
| invoked from within
| "get_node_object / dummy.dtsi"
| invoked from within
| "create_dt_node -name cpus -objects [get_node_object / dummy.dtsi]"
| ("eval" body line 1)
| invoked from within
| "eval "create_dt_node ${cmd}""
| (procedure "add_or_get_dt_node" line 183)
Re: ERROR: [Hsi 55-1545] Problem running tcl command ::sw_cpu_cortexa53::generate
Can you pass on the HDF please.
Generally a good way to isolate these issues from the Petalinux is to try create the devicetree manually from the devicetree generator.
The flow for this can be seen in the wiki here
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841722/ZCU102+Image+creation+in+OSL+flow
See the devicetree section.
However, if you pass on the HDF. I can take a quick look, and see what the problem is
Visitor rrx
thanks .. got patches ... so I am set ...
