ERROR: Unable to start bitbake server
Hai ,
I recently installed petalinux 2019.1 ,and working on adrv9009 .Created new project and adding path [ meta-adi-core and  meta-adi-xilinx] on petalinux-config --get-hw-description yocto settings user layes ,after save and exit iam facing this issue.
ERROR: Server log for this session (/home/fpga/mani_petalinux/interpolation/build/bitbake-cookerdaemon.log):
ERROR: Layer adi-xilinx is not compatible with the core layer which only supports these series: thud (layer is compatible with rocko).
can u please tell me  how to slove this issue...
Re: ERROR: Unable to start bitbake server
Hi @manibenwa
From this below error message
I can understand the meta-adi-xilinx layer is not compatible with petalinux 2019.1 (As 2019.1 uses yocto's thud release)
So, you cant use this meta layer with 2019.1. You can, however, use it yocto's rocko release meta layer (Or petalinux 2018.3 in simple words)
Best Regards
Shabbir
I am using petalinux 18.3. But i get this error
Layer adi-xilinx is not compatible with the core layer which only supports these series: rocko (layer is compatible with thud)
How can i solve this?
regards...
