ERROR: fsbl compile failed / ERROR: Function failed: do_compile
I was using "petalinux-build". And error occurs during the process:
13:10:20 Build Finished (took 51s.315ms)
Building '/fsbl'
ERROR: fsbl compile failed.
WARNING: /home/etdjj/AND/prj/base/build/tmp/work/plnx_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/temp/run.do_compile.26015:1 exit 1 from 'exit 1'
ERROR: Function failed: do_compile (log file is located at /home/etdjj/AND/prj/base/build/tmp/work/plnx_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/temp/log.do_compile.26015)
But I can't find any error message in the file "log.do_compile.26015". I have attached this file.
Re: ERROR: fsbl compile failed / ERROR: Function failed: do_compile
Did you export proper CROSS_COMPILE and ARCH?
If you run command
aarch64-none-elf-gcc
without any input file what do you see?
Proper compiler prefixes you can find here: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842547/Install+Xilinx+Tools
