Embedded linux system are not stable
My linux system on the zynq arm are not stable.
Sometimes it will stop to some place when booting.
But some times it will work. However, it will crush sometimes:
How could I debug the system?
[  231.020234] INFO: rcu_sched self-detected stall on CPU
[  231.025299]  0-...: (5249 ticks this GP) idle=afb/140000000000001/0 softirq=8        52/852 fqs=2625
[  231.033807]   (t=5250 jiffies g=238 c=237 q=10)
[  231.038313] Task dump for CPU 0:
[  231.041524] kworker/u8:0    R  running task        0     6      2 0x00000002
[  231.048566] Workqueue: edac-poller edac_device_workq_function
[  231.054282] Call trace:
[  231.056720] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[  231.062100] [<ffffff80080882e4>] show_stack+0x14/0x20
[  231.067134] [<ffffff80080c04ac>] sched_show_task+0x94/0xf0
[  231.072602] [<ffffff80080c26d8>] dump_cpu_task+0x40/0x50
[  231.077899] [<ffffff800812e258>] rcu_dump_cpu_stacks+0xb4/0xe8
[  231.083714] [<ffffff80080e8474>] rcu_check_callbacks+0x67c/0x860
[  231.089703] [<ffffff80080ebb2c>] update_process_times+0x34/0x60
[  231.095605] [<ffffff80080fafe0>] tick_sched_handle.isra.4+0x38/0x48
[  231.101854] [<ffffff80080fb034>] tick_sched_timer+0x44/0x90
[  231.107409] [<ffffff80080ec5e8>] __hrtimer_run_queues+0xf0/0x178
[  231.113398] [<ffffff80080ec978>] hrtimer_interrupt+0x98/0x1c8
[  231.119130] [<ffffff80086db8e8>] arch_timer_handler_phys+0x30/0x40
[  231.125291] [<ffffff80080dee70>] handle_percpu_devid_irq+0x78/0x128
[  231.131542] [<ffffff80080d9b74>] generic_handle_irq+0x24/0x38
[  231.137268] [<ffffff80080da1ec>] __handle_domain_irq+0x5c/0xb8
[  231.143083] [<ffffff80080814cc>] gic_handle_irq+0x64/0xc0
[  231.148464] Exception stack(0xffffffc0758bbb90 to 0xffffffc0758bbcc0)
[  231.154888] bb80:                                   0000000000000000 ffffff80        0865ad88
[  231.162707] bba0: 0000000000000000 0000000000000001 ffffffc077f83598 ffffffc0        77f83580
[  231.170519] bbc0: 0000000000000000 0000000000000000 ffffffc0758aa960 ffffffc0        758b8000
[  231.178331] bbe0: 0000000000000780 0000000000000000 000000000001480a 00000000        00000000
[  231.186142] bc00: 0000000000000000 0000000000000000 0000000000000000 00000000        00000000
[  231.193955] bc20: 0000000000000000 0000000000000000 0000000000000000 ffffff80        0865ad88
[  231.201767] bc40: 0000000000000000 ffffff8009499580 ffffff8009417000 ffffff80        09417000
[  231.209579] bc60: ffffffc0758bbd48 ffffffc07586fc78 ffffffc07586fea8 ffffffc0        758bbcc0
[  231.217391] bc80: ffffff800865afbc ffffffc0758bbcc0 ffffff80080ff958 00000000        60000145
[  231.225203] bca0: ffffffc0758bbd40 ffffff800886511c ffffffffffffffff ffffff80        0809a088
[  231.233014] [<ffffff80080827b0>] el1_irq+0xb0/0x140
[  231.237870] [<ffffff80080ff958>] smp_call_function_single+0x88/0x128
[  231.244206] [<ffffff800865afbc>] cortex_arm64_edac_check+0x7c/0xd8
[  231.250369] [<ffffff80086571b0>] edac_device_workq_function+0x78/0xc0
[  231.256793] [<ffffff80080b0474>] process_one_work+0x[  609.092229] INFO: rcu_sched self-detected stall on CPU
[  609.097285]  0-...: (99389 ticks this GP) idle=afb/140000000000001/0 softirq=852/852 fqs=49685
[  609.105971]   (t=99768 jiffies g=238 c=237 q=455)
[  609.110650] Task dump for CPU 0:
[  609.113862] kworker/u8:0    R  running task        0     6      2 0x00000002
[  609.120895] Workqueue: edac-poller edac_device_workq_function
[  609.126619] Call trace:
[  609.129055] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[  609.134438] [<ffffff80080882e4>] show_stack+0x14/0x20
[  609.139471] [<ffffff80080c04ac>] sched_show_task+0x94/0xf0
[  609.144940] [<ffffff80080c26d8>] dump_cpu_task+0x40/0x50
[  609.150235] [<ffffff800812e258>] rcu_dump_cpu_stacks+0xb4/0xe8
[  609.156051] [<ffffff80080e8474>] rcu_check_callbacks+0x67c/0x860
[  609.162040] [<ffffff80080ebb2c>] update_process_times+0x34/0x60
[  609.167942] [<ffffff80080fafe0>] tick_sched_handle.isra.4+0x38/0x48
[  609.174192] [<ffffff80080fb034>] tick_sched_timer+0x44/0x90
[  609.179747] [<ffffff80080ec5e8>] __hrtimer_run_queues+0xf0/0x178
[  609.185737] [<ffffff80080ec978>] hrtimer_interrupt+0x98/0x1c8
[  609.191466] [<ffffff80086db8e8>] arch_timer_handler_phys+0x30/0x40
[  609.197628] [<ffffff80080dee70>] handle_percpu_devid_irq+0x78/0x128
[  609.203879] [<ffffff80080d9b74>] generic_handle_irq+0x24/0x38
[  609.209605] [<ffffff80080da1ec>] __handle_domain_irq+0x5c/0xb8
[  609.215421] [<ffffff80080814cc>] gic_handle_irq+0x64/0xc0
[  609.220802] Exception stack(0xffffffc0758bbb90 to 0xffffffc0758bbcc0)
[  609.227226] bb80:                                   0000000000000000 ffffff800865ad88
[  609.235045] bba0: 0000000000000000 0000000000000001 ffffffc077f83598 ffffffc077f83580
[  609.242857] bbc0: 0000000000000000 0000000000000000 ffffffc0758aa960 ffffffc0758b8000
[  609.250669] bbe0: 0000000000000780 0000000000000000 000000000001480a 0000000000000000
[  609.258481] bc00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[  609.266293] bc20: 0000000000000000 0000000000000000 0000000000000000 ffffff800865ad88
[  609.274105] bc40: 0000000000000000 ffffff8009499580 ffffff8009417000 ffffff8009417000
[  609.281917] bc60: ffffffc0758bbd48 ffffffc07586fc78 ffffffc07586fea8 ffffffc0758bbcc0
[  609.289729] bc80: ffffff800865afbc ffffffc0758bbcc0 ffffff80080ff958 0000000060000145
[  609.297541] bca0: ffffffc0758bbd40 ffffff800886511c ffffffffffffffff ffffff800809a088
[  609.305353] [<ffffff80080827b0>] el1_irq+0xb0/0x140
[  609.310207] [<ffffff80080ff958>] smp_call_function_single+0x88/0x128
[  609.316544] [<ffffff800865afbc>] cortex_arm64_edac_check+0x7c/0xd8
[  609.322707] [<ffffff80086571b0>] edac_device_workq_function+0x78/0xc0
[  609.329130] [<ffffff80080b0474>] process_one_work+0x1bc/0x380
[  609.334858] [<ffffff80080b0680>] worker_thread+0x48/0x4a8
[  609.340239] [<ffffff80080b6294>] kthread+0xd4/0xe8
[  609.345013] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
Re: Embedded linux system are not stable
May I know the host details of your PC, I mean RAM size and no.of cores etc.,on which you are running Petalinux? Are you using virtual box or normal linux distro?
May be as a quick try, try disabling the CONFIG_CPU_IDLE in petalinux and check to see if it makes any progress:
petalinux-config –c kernel -à CPU Power Management -à CPU Idle -à CPU idle PM support
Best Regards
Shabbir
If it makes you feel any better, I'm seeing the same thing.  Same stack footprint you are.
I will let you know if I figure anything out, please do the same.
Rich
Hi @rschmitt Thanks.
I thought I am the only one has the same problem. Haha.
BTW which version of petalinux are you using now. I am using the 2017.1 version.
Best Regards
Shabbir
Hi, I'm running the Xilinx Linux tagged with v2017.1.  We are running it on a zynqmp based board.  For the most part, it is just the standard linux.  We have a few patches but nothing this low level.
One thing I did do was to disable the cortex edac work queue and the issue went away.  I don't see this as a solution, rather a piece of evidence.  My thinking is we are probably receiving a lot of edac events which cause the workqueue to run non-stop.  There are two firsts involved in this.  The first "first" is that we had just upgraded from the 2016.4 based SDK and the second "first" is that this is a new board for me to test with.  In my previous testing with the 2016.4 Linux and a different board, I never saw this issue.
On Monday I will be trying with a different board.  My question to the first guy who reported this is whether he saw his issue on more then one board?  And another question is whether he had run the 2016.4 kernel and if he had ever seen it then?
I'll update you after I try another board.
Rich
Rich,
Currently disabling EDAC drivers is the right solution as this is a know issue. Alternatively you can use anyone of this method.
Workaround 1: Add cpuidle.off=1 option in bootargs.
Workaround 2: Remove CONFIG_EDAC_ZYNQMP_OCM and CONFIG_EDAC_CORTEX_ARM64 options from linux.
Workaround 3: Disable low power mode "echo 1 > /sys/devices/system/cpu/cpu1/cpuidle/state1/disable"
Also check your device-tree settings and see if you can increase to 800ms
With this it will avoid cores entering into deeper states aggressively which might help on your device.
min-residency-us = <0x000186a0>; //100ms
min-residency-us = <0x000c3500>; // 800ms
Sandeep
Hello friends,
This is how I solved the problem (at least I think I solved it).
petalinux-config -c kernel
General setup>IRQ subsystem>enable Expose hardware/virtual IRQ mapping
General setup>Timers subsystem>Timer tick handling> choose Periodic timer ticks (constant rate, no dynticks)
petalinux-build
I think with these modifications the problem has gone. I am testing my board for few days and has not seen the problem yet, but please let us know if after these modifications you still have the problem.
@shabbirk
Thanks very much.
You are right.  After disable the "CPU idle PM support", the system runs well.
The self-detected stall means that some kernel operation is taking too long. Usually that means that the CPU is bogged down and can't keep up or that something running in kernel space has a bug.
I ran into this issue with the zcu102. Very repeatable, very frequent. I tried different hardware. I tried swapping out the kernel for a different version. I tried changing realtime options (preempt, etc). The only way I was able to fix it was to entirely disable EDAC (Error Detection and Correction) in the kernel. I'm not sure what the tradeoffs are, but seeing as EDAC is a fairly new feature, I think going without it will probably be ok.
It's under Device Drivers -> EDAC (Error Detection And Correction) reporting.
AR https://www.xilinx.com/support/answers/69433.html is available for this.
Sandeep
The other issue mentioned in this thread is likely addressed by:
https://www.xilinx.com/support/answers/69143.html
Hi @bryanloz ,
I have met the same problem. But I just try configure follow https://www.xilinx.com/support/answers/69143.html
Then I still met this problem.
I have try both Disable from the kernel config (CONFIG_CPU_IDLE) using PetaLinux or Yocto and add bootargs  = cpuidle.off=1 in Kernel Bootargs.
How solve this problem?
