Newbie jmarcao
Emulating QSPI in QEMU during U-Boot
We are using a Arty Z7-10 development board with a Zynq 7000 processor and XC7Z010-1CLG400C FPGA. We have a software solution that access the QSPI flash while in UBOOT before loading Linux. Both are built using the Petalinux tools.
We are having issues emulating UBoot in QEMU. Launching the emulation through petalinux ( petalinux-boot --qemu --u-boot ) we are able to see the U-Boot output, but we cannot access the QSPI and run into many errors, since calls to it have no hardware to connect to. Is it possible to emulate the QSPI device using QEMU? If so, is it possible to recover and re-use the QSPI storage?
The full command that petalinux executes is below:
qemu-system-aarch64 -M arm-generic-fdt-7series -machine linux=on -serial mon:stdio -serial /dev/null -display none -kernel <BUILD_PATH>/images/linux/u-boot.elf -gdb tcp::9000 -dtb <BUILD_PATH>/images/linux/system.dtb -net nic,vlan=1 -net user,vlan=1,tftp=<BUILD_PATH>/images/linux -net nic -device loader,addr=0xf8000008,data=0xDF0D,data-len=4 -device loader,addr=0xf8000140,data=0x00500801,data-len=4 -device loader,addr=0xf800012c,data=0x1ed044d,data-len=4 -device loader,addr=0xf8000108,data=0x0001e008,data-len=4 -device loader,addr=0xF8000910,data=0xF,data-len=0x4 -sd /dev/sdb
Thank you,
J
Tags (3)
Re: Emulating QSPI in QEMU during U-Boot
Hi @jmarcao
Are you able to detect the flash with uboot's sf probe 0 0 command?
I tried at our end with zynq7000 petalinux bsp, I dont see any issues
Best Regards
Shabbir
Newbie jmarcao
Hello Shabbir,
Thanks for your response.
Executing the command requested returns the following:
SF: unrecognized JEDEC id bytes: 20, 20, 14
It seems like we can  detect the flash, but it is rejected based on its ID. Is there an option to accept unrecognized JEDEC id bytes? Or is an unrecognized ID a symptom of a larger issue?
EDIT: This command returns no error on hardware and everything executes normally on the flash (read, write, etc.)
Thank you,
J
Make sure you are using the same device tree file that have been used while booting the hardware.
On ZC702 BSP, we have this flash
Zynq> sf probe 0 0
SF: Detected n25q512 with page size 256 Bytes, erase size 4 KiB, total 64 MiB
Best Regards
Shabbir
