Visitor deboleena18
Error: File name too long : Building linux-xilinx kernel
hi i m getting the following error, irrespective of the make target
this is just one example with target as clean
droy@m4210-01 ~/linux-xlnx-master $ make ARCH=microblaze clean
scripts/Makefile.clean:17: /home/droy/linux-xlnx-master/drivers/net/ethernet/smsc/Makefile: File name too long
make[4]: stat: /home/droy/linux-xlnx-master/drivers/net/ethernet/smsc/Makefile: File name too long
make[4]: *** No rule to make target `/home/droy/linux-xlnx-master/drivers/net/ethernet/smsc/Makefile'.  Stop.
make[3]: *** [drivers/net/ethernet/smsc] Error 2
make[2]: *** [drivers/net/ethernet] Error 2
make[1]: *** [drivers/net] Error 2
make: *** [_clean_drivers] Error 2
additional info
downloaded linux-xilinx kernel from xilinx github
board - ml509 (xupv5lx110t)
this is my first time with linux on fpga´s, so please tell me what i m missing and what can be done.
Tags (3)
Visitor deboleena18
Re: Error: File name too long : Building linux-xilinx kernel
the problem was in the makefile,
it was not a file but somekind of a link to a set of commands
droy@m4210-01 ~/xlnx $ cd /home/droy/xlnx/drivers/net/ethernet/smsc/
droy@m4210-01 ~/xlnx/drivers/net/ethernet/smsc $ ls -l
total 512
-rw-r--r-- 1 droy droy 45583 Apr  4 01:48 epic100.c
-rw-r--r-- 1 droy droy  4598 Apr  4 01:48 Kconfig
lrwxrwxrwx 1 droy droy   312 Jun 13 15:32 Makefile -> #?# Makefile for the SMSC network device drivers.?#??obj-$(CONFIG_SMC9194) += smc9194.o?obj-$(CONFIG_SMC91X) += smc91x.o?obj-$(CONFIG_PCMCIA_SMC91C92) += smc91c92_cs.o?obj-$(CONFIG_EPIC100) += epic100.o?obj-$(CONFIG_SMSC9420) += smsc9420.o?obj-$(CONFIG_SMC911X) += smc911x.o?obj-$(CONFIG_SMSC911X) += smsc911x.o?
-rw-r--r-- 1 droy droy 58586 Apr  4 01:48 smc911x.c
-rw-r--r-- 1 droy droy 32949 Apr  4 01:48 smc911x.h
-rw-r--r-- 1 droy droy 44236 Apr  4 01:48 smc9194.c
-rw-r--r-- 1 droy droy  6859 Apr  4 01:48 smc9194.h
-rw-r--r-- 1 droy droy 60215 Apr  4 01:48 smc91c92_cs.c
-rw-r--r-- 1 droy droy 63310 Apr  4 01:48 smc91x.c
-rw-r--r-- 1 droy droy 35322 Apr  4 01:48 smc91x.h
-rw-r--r-- 1 droy droy 70041 Apr  4 01:48 smsc911x.c
-rw-r--r-- 1 droy droy 12546 Apr  4 01:48 smsc911x.h
-rw-r--r-- 1 droy droy 44674 Apr  4 01:48 smsc9420.c
-rw-r--r-- 1 droy droy  8584 Apr  4 01:48 smsc9420.h
so i instead created a makefile and put the the commands in that and it worked.
Visitor deboleena18
total 512
Newbie andrewop
Hello
use long path tool, it is easy to use and solve your problem
_______________
