Error booting in Ultra96 with Petalinux 2018.2
Hi, when im turning on the Ultra96 with the Petalinux in the SD (First Part. with BOOT.bin and image.ub and Second Part. with RootFS) i got this error:
ZynqMP> ▒Xilinx Zynq MP First Stage Boot Loader
Release 2018.2 Nov 19 2018 - 17:22:00
PMUFW: v1.0
U-Boot 2018.01 (Nov 19 2018 - 17:18:39 +0100) Xilinx ZynqMP ZCU100 RevC
I2C: ready
DRAM: 2 GiB
usb dr_mode not found
EL Level: EL2
Chip ID: zu3eg
MMC: Card did not respond to voltage select!
mmc_init: -95, time 27
sdhci@ff170000 - probe failed: -95
sdhci@ff160000: 0 (SD)Card did not respond to voltage select!
In: serial@ff010000
Out: serial@ff010000
Err: serial@ff010000
Board: Xilinx ZynqMP
Bootmode: SD_MODE
U-BOOT for aic_demo
Hit any key to stop autoboot: 0 Card did not respond to voltage select! mmc_init: -95, time 28 ** Bad device mmc 1 ** Device: sdhci@ff160000 Manufacturer ID: 1d OEM: 4144 Name: SD Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 14.7 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes Card did not respond to voltage select! mmc_init: -95, time 27 ** Bad device mmc 1 **
can someone help me ?
Re: Error booting in Ultra96 with Petalinux 2018.2
Hi @francocapraro12
Please refer this below  post, it is similar issue and it is having solution.
:https://forums.xilinx.com/t5/Embedded-Linux/U-boot-boot-failure/td-p/451704
Thanks & regards
Aravind
