Visitor iomartin
Error building Petalinux
My petalinux build is failing with error
make[3]: *** No rule to make target 'arch/microblaze/boot/dts/mb.dtb', needed by 'arch/microblaze/boot/dts/system.dtb'.  Stop.
make[2]: *** [/local/scratch/ichilevi/petalinux_project/build/tmp/work-shared/plnx-microblazeel/kernel-source/Makefile:1052: arch/microblaze/boot/dts] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:146: sub-make] Error 2
make: *** [Makefile:24: __sub-make] Error 2
ERROR: oe_runmake failed
WARNING: exit code 1 from a shell command.
ERROR: Function failed: do_compile (log file is located at /local/scratch/ichilevi/petalinux_project/build/tmp/work/plnx_microblazeel-xilinx-linux/linux-xlnx/4.19-xilinx-v2019.1+gitAUTOINC+9811303824-r0/temp/log.do_compile.2663)
I created the petalinux project as follow:
petalinux-create --type project --template microblaze --name petalinux_project
cd petalinux_project
petalinux-config --get-hw-description ../vivado/project_1/project_1.sdk --silentconfig
petalinux-build
My design is attached. The logfile is also attached. Target board is Alveo U280-ES1. Please let me know if you need anything else.
Re: Error building Petalinux
Can you remove the silent config
See if there is any issue here as this is where the DT will be setup
