Visitor toshibo
Error -> bootgen: command not found
Dear all,
I am trying to generate BOOT image for my zedboard.
I am using  petalinux 2013.04 running on ubuntu 11.04.
I am following this guide:
http://www.wiki.xilinx.com/Zynq+Base+TRD+2013.2
I already built petalinux (step 10).
I already generated all files needed (.bit and .elf) but as soon as I try to generate the boot image, I obtain:
$petalinux-gen-zynq-boot: line 291: bootgen: command not found
$ERROR: Fail to create BOOT image
I guess it to be a problem with EDK/SDK but I set my XILINX_EDK variable where the bootgen file is!
In fact, by using
 $ env
I obtain
XILINX_EDK=/opt/Xilinx/SDK/2013.2/bin/lin/bootgen
what should I do?
Visitor toshibo
Re: Error -> bootgen: command not found
Sorry...my fault.
To have not that error, you have to check to have the file with bootgen in your path.
Regards.
In general it is a good idea to source the settings64.sh script (or equivalent for 32 bit architecture or csh shell) from the IDS/Vivado installation directory before sourcing the PetaLinux setup script. This will put all the required Xilinx tools in the search path.
