Error in ruby-native build
I am trying to follow reference design of xilinx (Zynq UltraScale MPSoC Base TRD 2017.2 - Design Module 1).
I followed mentioned steps, now I am trying to build the provided project using "petalinux-build"
However I faced currently an error
"ERROR: ruby-native-2.2.5-r0 do_compile: oe_runmake failed"
I have no other clue how to handle this error as it is my first time working with Petalinux.
I check log files of building ruby and I found the following
I hope someone can help to figure out what is the problem
To overcome this problem go to
<petalinux_inst_dir>/petalinux/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/ruby/
then open this file "ruby_2.2.5.bb" and add the mentioned (highlighted) option in the shown section
Can you please let me know what petalinux steps you have followed to build the project?
Best Regards
Shabbir
@shabbirk
Actually it is only one step that I have followed so far which is "petalinux-build"
(it is available in this link)
I tried to search online, some forums advise to disable making the rdoc in Ruby. This can be done when installing Ruby by directing the configuration using the option "
RUBY_CONFIGURE_OPTS=--disable-install-rdoc
What I want to do now is to know how petalinux is building Ruby. I mean I want to know where exactly can I define the mentioned option to control configuration of Ruby.
It is my first time working with petalinux so I don't know from where the make files are invoked
