yinlinlijuan
Error occured when I try to build opencv in sdk2016.04
Hi all,
 Here is my all system environment,
   Ubuntu16.04 or Centos7, SDK2016.04, opencv3.2.0, cmake3.8.0
 There is a attachment which is configurtion in cmake gui.
 The error message in terminal is as below,
imgcodecs/CMakeFiles/opencv_imgcodecs.dir/src/exif.cpp.obj
[ 44%] Linking CXX shared library ../../lib/libopencv_imgcodecs.so
/opt/Xilinx/SDK/2016.4/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/5.2.1/../../../../aarch64-linux-gnu/bin/ld: ../../3rdparty/lib/libIlmImf.a(ImfHeader.cpp.obj)(.text._ZNK3Imf6Header7writeToERNS_7OStreamEb+0x3a8): 无法解决 R_AARCH64_ADR_PREL_PG_HI21 重定向于符号 “_ZTVNSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEEE@@GLIBCXX_3.4.21” 有冲突
/opt/Xilinx/SDK/2016.4/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/5.2.1/../../../../aarch64-linux-gnu/bin/ld: final link failed
collect2: error: ld returned 1 exit status
modules/imgcodecs/CMakeFiles/opencv_imgcodecs.dir/build.make:572: recipe for target 'lib/libopencv_imgcodecs.so' failed
make[2]: *** [lib/libopencv_imgcodecs.so] Error 1
CMakeFiles/Makefile2:2328: recipe for target 'modules/imgcodecs/CMakeFiles/opencv_imgcodecs.dir/all' failed
make[1]: *** [modules/imgcodecs/CMakeFiles/opencv_imgcodecs.dir/all] Error 2
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2
